586,788 active members*
2,778 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Ambigious tool pocket
Results 1 to 6 of 6
    Aug 2006
    24
    I have an 'ambigious tool pocket' error that will not reset. Dual arm type changer.
    SETTO,# does not work for some reason.
    any ideas?
    Aug 2006
    24
    After another power down then turret rotation, apears OK. No idea what caused the fault in the first place tho.
    Aug 2006
    24
    Back again.
    It would appear that I am having an intermittent problem with the turret rotation. Going to check the proximity switch now.
    Mar 2005
    7
    type DI at enter next command and type DD you will goto the DATC diagnostics page . bets are that you are stuck slightly between buckets . use this menu to correct the problem .
    if you need help just call the service department at 818 727 2100
    CNC BimboCNC BimboCNC Bimbo
    Mar 2005
    7
    Quote Originally Posted by Dsny View Post
    Back again.
    --- you should be able to tell on the diagostics page if the switch is bad . at DI DD look at the bottom of the menu and you will see if it is open or closed on the switch ...
    Aug 2006
    24
    The pin that attaches the brake to the shaft had busted.
  1. G77 Circular Pocket
    By Big John T in forum BobCad-Cam
    Last Post: 02-27-2007, 05:33 PM
  2. Complete Pocket PC DNC
    By BigBobH in forum News Announcements
    Last Post: 02-17-2007, 11:28 PM
  3. Open Pocket
    By camtd in forum EdgeCam
    Last Post: 10-23-2006, 07:09 PM
  4. Pocket help
    By tt_raptor_90 in forum Mastercam
    Last Post: 06-20-2006, 03:37 PM
