Guys
Sorry if this has been asked- Im not finding much via search engines-
Core issue is that Im running a Tormach Tool System on a mill I converted to CNC- which as most of you know fixes Z well enough to permit use of a tool length table without referencing tools to some external device each tool change. Im running MACH3 to control this machine.
In a case where I'm running a larger program, and have a need for some random tool that is rarely used (no TTS holder for it- where all are allocated to the frequently needed tools in the project), and need to set the depth for that manually during the program cycle, how do I best accomplish that? I cannot simply touch off the tool, leaving its table length entry as zero, and zeroing the DRO for that coordinate system, since that would screw up the coordinate system for the other tooling (based on some master tool…).
Am I better off dynamically populating the tool length offset in the table for that (uncommonly-used tool)? Am I better off just copying X and Y values from the working coordinate system (G54) to some other (i.e. G55), and then zeroing Z there just for that tool, with a coordinate system change in the code? That seems a huge hassle.
I just don’t know how people deal with this- where maybe you find that a tool used mid-program is damaged and needs to be replaced before insert. There must be a way that doesn’t require a program restart/run-from-here to deal with it, but I don’t see any simple way to do this that doesn’t require rezeroing the coordinate system after the use of the ‘underdefined’ tool…
Any help is much appreciated
Best
