586,096 active members*
3,811 visitors online*
Results 1 to 10 of 10
    Aug 2017
    112
    INVERSE TIME FEEDRATE OPTION FOR 6 AXIS
    Hi All
    I am using Kflop board for 5 axis. But now i want to use the same for 6 axis as well.
    Inverse time feedrate option available in kflop is for 5 axis only.
    I want to know that how do i use the same inverse time feedrate for 6 axis. eg X,Y,Z,A,B,C.
    Waiting for your kind reply.
    Thank You
    Regards
    Amit Kumar
    May 2006
    4045
    Re: INVERSE TIME FEEDRATE OPTION FOR 6 AXIS
    Hi Amit,
    Inverse time should work for any number of axes. Why do you say it is only available for 5 axes?
    Regards
    TK
    http://dynomotion.com
    Aug 2017
    112
    Quote Originally Posted by TomKerekes View Post
    Hi Amit,
    Regards
    Hi tom, i want to know how to turn off inverse time feedrate option for 5 axes because it is causing jerk in machine movement.
    I want to make machine movement smooth that is only possible without inverse time feedrate. How to turn it of for X,Y,Z,A,C axes.
    Regards
    Amit Kumar
    May 2006
    4045
    Hi Amit,
    I'm confused. In your first post you seem to want to use inverse time for 6 axes? Now you don't want inverse time for 5 axes?
    Anyway,
    G93 sets the Feed Mode to inverse time.
    G94 set the Feed Mode to units per minute.
    So use G94 to turn off inverse time feedrate.
    Can you provide a simple GCode example of "jerky" motion?
    Regards
    TK
    Aug 2017
    112
    Hi tom,
    i am using following g code
    G1 X-3.096 Y-41.478 Z70.724 A90.021 C-3.509 F1000
    TO
    G1 X-5.052 Y-45.586 Z65.724 A85.092 C-5.365 F1000
    But when i run the g code in kmotion cnc i am getting feed of 5 and 6 MMPM but as i said in g code it is f1000 so it should be 1000 right.
    How to make the feed rate from 5-6mmpm to 1000 mmpm or constant feedrate for 5 axis.
    waiting for your kind reply.
    Regards
    Amit Kumar
    May 2006
    4045
    Hi Amit,
    For me that GCode executes in ~ 0.4seconds which seem about correct. For you it takes ~ 1minute ?
    What are all your Trajectory Planner Settings?
    Regards
    TK
    Aug 2017
    112
    Hi Amit,
    Regards
    Here are the settings
    Let me know
    Sent from my Redmi Note 5 pro using Tapatalk
    Regards
    Amit Kumar
    May 2006
    4045
    For me that second line of GCode executes in ~ 0.4seconds which seems about correct. For you it takes ~ 1minute ? Yes or no? How long does it take for you?
    TK
    Aug 2017
    112
    Yes it takes one minute
    Regards
    Amit Kumar
    May 2006
    4045
    Hi Amit,
    Like I said we don't see the problem here. So you will need to tell us what you are doing different.
    Post your Init C Program and all GCode before the two lines of GCode.
    Regards
    TK
  1. 4th axis inverse time feed rates
    By hotiron in forum Fanuc
    Last Post: 10-22-2015, 01:24 PM
  2. 4 and 5 axis post question (inverse time feed)
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 11-22-2013, 12:46 AM
  3. Inverse time- 5 axis Acramatic 950
    By hyperMan in forum Cincinnati CNC
    Last Post: 10-01-2010, 03:46 PM
  4. Inverse Time feedrate for 4th Axis
    By slideleft in forum Haas Mills
    Last Post: 12-09-2008, 04:39 AM
  5. Inverse time feeds with a 4th axis
    By nervis1 in forum Fadal
    Last Post: 11-06-2004, 06:43 AM
