586,082 active members*
3,585 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Stepper to SerVo motor change-out
    Sep 2018
    Hey all,
    I am new on here and have a question regarding changing out my 2006 (year) Vexta (model ASM911AA) stepper motors (DC 2.56V, 2.1A) for new servo motors. I am running a 5x8 table w/ a HSD 4kw ER25 spindle which almost exclusively cuts wood. I have had GREAT luck w/ the steppers but I am itching to increase my CNC output by improving the motors. Any suggestions or recommendations about brands and change-out pit falls?
    BTW, I am also getting a new "good enough" 4kw ER25 spindle/VFD ($650 all in) so I can have my HSD 4kw ER25 rebuilt ($1,200). Been considering the Chinese manufacturer Changzhou Hua Jiang Electric Co. who seems to own the Alibaba, AliExpess and Ebay channels in the low-mid tier spindles. Feel free to share any thoughts about spindle/VFD upgrade as well.
    https://www.ebay.com/p/Square-4kw-Ai...3327128&chn=ps
    Cheers everyone,
    '06 Shopbot still running strong!
    Dec 2013
    5717
    Re: Stepper to SerVo motor change-out
    The DMM servos are nice, I've installed a few of them. DMM | AC SERVO DRIVE | AC SERVO MOTOR | ROTARY ENCODER
    Also the ClearPath servos work well, I put a set on a customer machine and just ordered 4 more for the next upgrade on his other machine. https://www.teknic.com/products/clea...-servo-motors/
    Either brand will take a step & direction input and close the loop at the drive.
    Jim Dawson
    Sandy, Oregon, USA
    Jun 2011
    692
    Looks like those Vexta steppers are almost NEMA 34 frame. Mounting hole spacing is a tiny bit off (probably close enough though,) and the pilot boss diameter is much smaller (60mm vs 73mm on a standard NEMA 34.) If their current mount uses the pilot boss as an alignment feature, you'll need an adapter plate. Also looks like it uses a 14mm shaft, which you don't usually see on NEMA frame steppers (common on metric servos though.)
    Also, those look to be pretty high performance steppers according to the datasheet. 4Nm holding torque and up to 4000 RPM?
    You're looking for higher speeds, precision or both?
    What are your max cutting/rapid speeds now?
  1. How to identify a stepper motor and AC servo motor? (by its appearance)
    By thanhvu94 in forum Stepper Motors / Drives
    Last Post: 01-26-2016, 12:57 AM
  2. Replacing broken analog servo motor with stepper motor
    By mitzpetel in forum Dynomotion/Kflop/Kanalog
    Last Post: 04-12-2015, 03:50 PM
  3. The difference between Stepper Motor and Servo Motor ROCTECH MACHINERY
    By ROCTECH-Vicky in forum Roctech CNC Routers
    Last Post: 10-30-2014, 06:59 AM
  4. Rotation Change to stepper Motor with driver EM705
    By marcoabril in forum Stepper Motors / Drives
    Last Post: 07-29-2014, 03:07 AM
  5. Servo motor? tool change issue
    By richpsr in forum Bridgeport / Hardinge Mills
    Last Post: 10-04-2011, 12:57 PM
