588,173 active members*
4,420 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Engraving in anodized aluminum
Results 1 to 7 of 7
    Mar 2007
    7
    We just got a RS3040A laser machine from Redsail, (hflaser.com). Everything we have engraved is ok so far. However, we are trying to engrave on colored anodized aluminum and it does not engrave anything, we set the machine to min. speed and max. power and it does not even scratch the color layer.
    The machine is 40 W power, from what I know it should engrave or is there any trick I´m missing?
    Thank you,
    Jose
    Feb 2006
    794
    I might be all wet here but maybe you should take a flow master and ink up the area where you want to engrave, the color will act like a mirror and what happens to a dirty mirror ? just a thought
    Don
    IH v-3 early model owner
    Mar 2007
    7
    ink for laser
    Hi Cruiser,
    Thanks for your help.
    Sounds it could work, but what sort of ink is it?. What´s the name or brand and where can I buy ot from?
    Thanks again.
    Feb 2006
    794
    Flow master or just plain ole felt tip marker ! actually i think anything to dirty the surface might be of use here, maybe ! try what ya got till it works.
    Don
    Jun 2007
    12
    You have to use a lot of speed and the frequency of the laser must be adjusted to mark on anodized aluminum. We mark on it all the time with the laser system we sell. Ostling Marking systems. The power can remain the same it has to do with frequency control and speed.
    Apr 2007
    641
    Hi all,
    I have a laser chinesse machine 60w, you need more power to engrave on anodized aluminium, on plain aluminium you will not engrave. Some spray is used to mark on aluminium, I saw it in a forum. Also have heard about the flow master but have not give a try, I will and tell.
    Luistry
    Aug 2007
    20
    If this is a co2 laser you'll need more power and slower engraving. So boost to 100% power and adjust your speed until you get the results you want. With that wattage you can engrave that material. You must also adjust your freq. for that material. Diff. materials cut and engrave at diff. freqs.
  1. Engraving anodized aluminum - color fill?
    By Neil_J in forum Hobby Discussion
    Last Post: 09-17-2008, 03:11 AM
  2. engraving anodized alum
    By srmaietta in forum Engraving Machines
    Last Post: 03-02-2007, 10:23 PM
  3. rfq on .125 aluminum engraving
    By cncsdr in forum Employment Opportunity
    Last Post: 01-23-2007, 01:34 AM
  4. Engraving aluminum......
    By Tyler Durden in forum MetalWork Discussion
    Last Post: 09-16-2006, 10:14 AM
  5. Anodized Aluminum Round Rod - Best Place To Buy It?
    By nlh in forum Material Machining Solutions
    Last Post: 12-02-2005, 04:54 PM
