586,075 active members*
4,267 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Controller Cards > NVUM CNC V1 Controller USB Version Does it work on windows 7 ?
    Dec 2017
    53
    Hi Guys
    Well i think the customer support here is 100% better than from Lollette Store
    I have a NVUM CNC V1 Controller USB Version
    I had it working well with Windows XP
    I bought a new PC and installed Windows 7 32 Bit and cant get it working at all, no axis moves with onscreen MPG
    Ive tried all day with various settings to no avail!
    So i emailed the Ali store and refused to help unless i gave them a order number, not interested in even asking my simple question, is this controller v1 USB capable of working with windows 7?
    Id also like to inform ALL OTHERS This model!!!!!!!! 100% IS NOT COMPTABILE With The LCD Display MPG Controller, only the manual mpg!
    If you want to use the NVMPG Controller please make sure you use the V2 version!!!!!!! they dont advertise that much!!!!!!!!!!
    also refused to answer my simple question if this model works with windows 7 32 bit?
    Does anyone else know? USB Version V1 not the V2 works with windows 7 32 bit??
    Dec 2017
    53
    Re: NVUM CNC V1 Controller USB Version Does it work on windows 7 ?
    NO one ever replys to my posts? Why?
  1. Which version of Windows will NCStudio work on?
    By Dbl_Tap in forum Chinese Machines
    Last Post: 07-07-2021, 08:35 PM
  2. Novusun NVUM controller + Spindle help
    By charlierj in forum Spindles / VFD
    Last Post: 01-14-2020, 04:48 AM
  3. NVUM CNC Controller setting it up with the DQ860MA Micro stepper Driver
    By adamfromUK in forum CNC Machine Related Electronics
    Last Post: 08-03-2018, 06:37 PM
  4. NVUM controller , the usb controler ...
    By Andreiir in forum Stepper Motors / Drives
    Last Post: 12-30-2016, 09:48 AM
  5. Mastercam version 17 and windows 7
    By cncwhiz in forum Mastercam
    Last Post: 02-10-2010, 09:52 PM
