Hello All-
This is my first post and my first CNC machine (new to me but not new). Thank you in advance for your time and patience, as I don't know g-code or xml or CAM software, only Rhino CAD.
SETUP : Little Machine Shop Mini Mill, FusionCNC conversion kit, Mach3, Windows 7 machine, Probotix PBX-RF breakout board running Probostep drivers.
1) Got Mach3 up and running and the motors were responding fine to both Jog and Continuous mode from both keyboard and xbox controller.
2) Started to setup step-per-unit in millimeters and the X setup went smoothly but in the Y setup, 1unit (1mm) keeps moving the jog 23mm no matter what I try. Is there a way to reset the step per unit to default?
3) When I moved on to the Z setup, the Z worked fine but now, both Z & X will only go in continuous only slowly, speed inbetween Jog and Continuous.
So, I am looking for a solution to the slow speed in Continuous and Y setup problem: Attached are:
• Screenshot of Program Run and Settings
• XML file from Mach3 "LMS_CNC.xml"
