586,106 active members*
3,134 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > OpenSource Software > any issues using dmap2gcode with UGS and GRBL
    Mar 2011
    357
    Do any of you know if dmap2gcode can be used with UGS and GRBL?
    I am building a GRBL based CNC router and want to cut 3D lake maps and dmap2gcode looks like an easy way to go but the doc mentions Linuxcnc so I was just wondering if it will work with UGS?
    Nov 2012
    154
    Re: any issues using dmap2gcode with UGS and GRBL
    Since dmap2gcode's changelog on its front webpage explicitly mentions GRBL I would expect it to work. In general, there's no reason why any g-code interpreter would not work with g-code meant for another one - except if it does not support some of the g-codes that the other one does. However, although it's certainly true that GRBL only supports a modest subset of all existing g-codes, typical and relatively simple machining operations should not really need or use any of the fancy stuff GRBL does not implement. So yeah, it should just work - but I have never used dmap2gcode, so I can't say for sure.
  1. GRBL PCB
    By crob09 in forum CNC Machine Related Electronics
    Last Post: 02-28-2018, 05:22 PM
  2. Replies: 1
    Last Post: 08-19-2016, 11:57 AM
  3. Replies: 3
    Last Post: 06-03-2016, 02:48 PM
  4. GRBL Pausing issues
    By gte718p in forum Arduino
    Last Post: 02-21-2016, 12:09 AM
