I'm sure this is a stupid question but here goes. I am building a temporary control box out of wood. I realize that the G540 housing isn't grounded to a metal computer case. My question is does it need to be grounded? If so should I run a ground wire from one of the mounting screws to the house/earth ground or should I run a ground wire from one of the mounting screws to the ground on the power supply? I guess the power supply and the earth ground would be the same thing...
~Pete
