603,374 active members*
4,386 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Mitsubishi Servo with Masso Controller
    Jul 2018
    Dear members
    I do not have much knowledge about electronics but I am interested in the field of application, I bought a controller card in Masso CNC Controllers: Run CNC Machines without a PC model HTG5A1S for my servo amplifier and Mitsubishi engine of the serious MR-J3-A.
    In the MR-J3-A user manual I have identified the control pins, the manufacturer of the controller card very kindly and he tells me that I must program my amplifier MR-J3-A in a "PULSE TRAIN + SIGN" way as seen in the attached figure.
    My doubt is that the pin of the HTG5A1S controller (S + S-D + D-Step & Direction) must be connected to the MR-J3-A amplifier pins.
    Attached images of the Mitsubishi MR-J3-A User Manual
    https://masso.com.au/forums/topic/so...1s-controller/
    [email protected]
    Thank you
    Jun 2011
    692
    Re: Mitsubishi Servo with Masso Controller
    If the servo drive is just an amplifier, I don't think the Masso will work with it. From a quick google on the MR-J3-A manual, it looks like it's a full servo control that can take step-dir inputs though. You;d need to set parameter PA13 to 0001h. Connections should be per the manual.
    Looks like it should be 1 to 1-10, 2 to 1-11, 3 to 1-35 and 4 to 1-36.
  1. Any User Input?? - Hind Technologies / Masso HTG5A1S Controller
    By NardisAmps in forum Controller & Computer Solutions
    Last Post: 05-18-2019, 07:06 PM
  2. Masso controller
    By Dean448 in forum Controller & Computer Solutions
    Last Post: 04-13-2019, 09:21 PM
  3. Prolight 1000 Mill upgrade with Masso controller
    By agoodevans in forum Benchtop Machines
    Last Post: 10-05-2018, 01:52 PM
  4. Masso Mill / Router CNC Controller
    By joemusso in forum Benchtop Machines
    Last Post: 09-28-2018, 12:27 AM
  5. Anyone using a Masso CNC controller? Thoughts
    By rcmcdee in forum DIY CNC Router Table Machines
    Last Post: 02-19-2018, 06:16 PM
