586,080 active members*
3,472 visitors online*
    Aug 2004
    104
    Wire Feeder MEF 44N
    Has anyone the electrical diagram of pins from Wirefeeder MEF 44N, ESAB?
    I would like to turn it on separeted from power source, whats is the beste way to do that?
    Nov 2013
    4375
    Re: Wire Feeder MEF 44N
    some of the very latest ESAB wirefeeders have either CAN-bus and/or multiple control voltages in the cable connecting the wirefeeder and the
    power source. Separating the wirefeeder for independent operation may not be easy/possible for this late model stuff.
    Earlier model wirefeeders are less complex and inepenent operation is possible.
    Can you post some pics of the feeder? Also pics of the cable plug and a shot of the socket from the inside of the feeder?
    Craig
    Aug 2004
    104
    Hi Creg,
    I will get that.
  1. welder wire feeder
    By laminated in forum Welding Brazing Soldering Sealing
    Last Post: 06-27-2018, 09:49 PM
  2. wire feeder
    By 0Jw in forum Other Machine Topics
    Last Post: 03-18-2017, 05:36 AM
  3. TIG Cold Wire Feeder MILLER DYNASTY 200 DX aluminium welding DIY
    By pinciui in forum Welding Brazing Soldering Sealing
    Last Post: 03-15-2012, 01:42 AM
