603,861 active members*
3,997 visitors online*
Thread: URGENT HELP
Results 1 to 6 of 6
    Nov 2018
    4
    URGENT HELP
    Going out of mind and have wasted soo much material. My laser isn't cutting in the middle of my sheets. I have an Epilog.
    The outer edges cut fine however middle parts loose power almost completely
    Photo attached, any help or advice would be greatly appreciated
    Sep 2018
    83
    Re: URGENT HELP
    The three things to generally look at with situations like this are: bed alignment, laser alignment and the state of your optics.
    I suspect that it's most likely to be crap on the optics, since that's the most common cause for issues like this (unless you've dropped something heavy on the bed recently). Examine the lens and the mirrors carefully - even a little discolouration on them can cause issues akin to this. Clean them with alcohol lens wipes or the nearest equivalent you can lay hands on.
    Nov 2018
    4
    Re: URGENT HELP
    I’ve cleaned the lens and mirrors .. was also told the issue could lie in the material but it’s not warped at all
    Sep 2018
    83
    Re: URGENT HELP
    How's your beam alignment looking? I'm not seeing any of the normal 'halo' I'd expect from a misaligned beam, but it's easier to check and resolve than a misaligned bed is.
    Mar 2016
    94
    Re: URGENT HELP
    Quote Originally Posted by Ellecee123 View Post
    HI
    we have this problem with 3 mm mdf, we have found it is in the winter months when there is more moisture content in the materials stored in cold warehouses and workshops
    we counter it by increasing power slightly during the winter and that cures the problem
    give it a try let us know
    Dave
    Nov 2018
    4
    We’re In Australia so it’s currently summer here.. materials are not cold at all ??QUOTE=Dtcrafts;2236716]HI
    Dave[/QUOTE]
  1. help urgent
    By dmoglianesi in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-25-2018, 09:22 AM
  2. EMERGENCY - NEED HELP SOURCING UK SUPPLIER - URGENT URGENT URGENT
    By ApexLaser in forum Want To Buy...Need help!
    Last Post: 07-19-2014, 04:37 PM
  3. Urgent Please
    By mrirfanamin in forum Phase Converters
    Last Post: 01-28-2011, 08:23 PM
  4. urgent
    By ashishpatil in forum DNC Problems and Solutions
    Last Post: 01-09-2011, 01:57 PM
  5. URGENT: 2J Quill return sping replacement -URGENT
    By NC Cams in forum Bridgeport / Hardinge Mills
    Last Post: 02-14-2006, 05:48 AM
