586,069 active members*
3,608 visitors online*
    Oct 2017
    15
    Fanuc Test Stand
    Hi all I am having problems getting the error of:
    410: Servo Alarm : X axis excess err
    can anyone help me solve the issue?
    Dec 2013
    39
    Re: Fanuc Test Stand
    Check the Motor cable and axis load , Jog in Low rpm and check the load
    Jan 2014
    106
    Check on the servo screen. X axis feedback while you try to handle the position on the CNC screen may be counting and expecting to move but the encoder value is not moving on the feedback screen..
    So yes check the motor cable, or see if the motor is jammed up.
  1. Fanuc Test System
    By learning_elec in forum Fanuc
    Last Post: 12-04-2018, 03:50 AM
  2. Replies: 1
    Last Post: 10-19-2018, 04:40 PM
  3. Fanuc Test Stand
    Last Post: 03-17-2018, 04:49 AM
  4. Replies: 0
    Last Post: 09-15-2015, 08:28 AM
  5. Can I lift my 1100 w/ the stand or should I remove the stand?
    By KSky in forum Tormach Personal CNC Mill
    Last Post: 05-15-2015, 09:12 PM
