586,112 active members*
3,217 visitors online*
    Nov 2004
    239
    Gear Out Position Error
    I am getting a gear out position error on my Romi 35E.
    As far as I can tell there are 4 switches. 2 are on the handle below the CRT.
    I believe the other 2 are on the headstock below the CRT. When the hydraulics come on there is a rod which engages a switch.
    This rod always extends to the right and engages the switch on the right.
    Not sure I'm on the right track.
    Nov 2004
    239
    Re: Gear Out Position Error
    Fixed. You have to select the gear through M11 or 12,13, or 14 as far as I could tell. All cleared up now.
  1. Position Error
    By sabine in forum Centroid CNC Control Products
    Last Post: 08-14-2018, 05:16 PM
  2. Position following error
    By bob1011 in forum Leadshine
    Last Post: 01-09-2017, 08:31 PM
  3. Yaskawa Servopack error: A.D1. Motor Load Position Excess Error
    By Syphonics in forum Servo Motors / Drives
    Last Post: 04-26-2012, 07:53 AM
  4. OLD UHU POSITION ERROR
    By dfv in forum UHU Servo Controllers
    Last Post: 03-22-2010, 06:16 PM
  5. K2 CNC position error - please help !
    By Geetar-ist in forum K2CNC
    Last Post: 09-13-2009, 10:24 PM
