586,116 active members*
3,469 visitors online*
    Feb 2014
    42
    Exclamation Fagor 8050T/8055T Restore with backup
    On one of the lathes with a Fagor 8050T / 8055T, the backup battery when dead.
    I got backup of the following files that I guess is the files needed to get it back up running again:
    PLC_ERR.PIT, PLC_MSG.PIT, PLC_PRG.PIT and 999996 to 999999.PIT.
    I have managed to connect the PC to the lathe with WinDNC and been able to get almost all files over to the lathe.
    One or two of the 999999_ files will not be copied since it has is write protected.
    How shall I get the PLC files and 999999_ files to work on the lathe? Do I need to copy them to the eeprom or is the files already on the eeprom?
    Why will not some files be copied since the write protection?
    Thank for your help in advance.
    Feb 2005
    69
    Re: Fagor 8050T/8055T Restore with backup
    Do you have the operator's manual that explains all of this? I can send you one if you don't have it. Here's what I found.
    "OEM programs
    PLC program, MSGFILE program, CFGFILE program, STPFILE, USR* program, PLC
    messages and PLC errors.
    If any of the programs described is not an OEM program, it will request confirmation to make
    it OEM. If you chose not to make it OEM, it will not be saved.
    OEM and hidden programs will be saved encrypted. When doing the Backup, OEM and hidden
    programs are encrypted based on the OEM password. If the Restore is carried out on a CNC
    with a different OEM password, the CNC will issue the error message "the program is protected"
    and will not allow restoring it.."
    "Passwords:Lets define each of the passwords that the operator must key in before accessing the various CNC
    commands.
    • General password (MASTERPSW)
    It is requested when trying to access this password option.
    (Utilities mode / Protections / Passwords).
    • OEM password (OEMPSW)
    It is requested when trying to access OEM permissions
    (Utilities mode / Protections / OEM permissions).
    • User password (USERPSW)
    It is requested when trying to access user permissions
    (Utilities mode / Protections / User permissions).
    • PLC access password (PLCPSW)
    It is requested in the following cases:
    When compiling the PLC program.
    When trying to change the status of a resource or execute a program execution controlling
    command.
    To protect the PLC program, the PLC message program and the PLC error program, modify their
    attributes so they are "Non-modifiable".
    • Customizing password (CUSTOMPSW)
    It is requested when trying to access the Customizing mode or when attempting to erase an OEM
    screen.
    • Machine parameter access password (SETUPPSW)
    It is requested when trying to access the options to modify the table values (Edit, Modify, Initialize,
    Delete and Load) except for tables of the serial lines which are not protected."
    Feb 2014
    42
    Thanks Factory Guy!
    I guess I will have to invstigate the problem with the write protection.
    Have you or any one else who had to restore a backup into a Fagor 8050 / 8055T?
    The backup is from the lathe and not from any other one.
    I can find videos o you tube for the 8055T, but not the 8050 / 8055T.
    Thanks in advance.
    Feb 2014
    42
    Quote Originally Posted by dunderdunder View Post
    Thanks Factory Guy!
    Thanks in advance.
    I got wrong tool in the machine vs turret, turret got tool two in position, but the Fagor control shows T1. Anyone know the parameter that needs to be changed to correct to get turret and control to be the same?
    Skickat från min SM-G955F via Tapatalk
  1. Fagor help needed in Austin TX, 8050T Lathe
    By KenCameron in forum Fagor Automation
    Last Post: 06-17-2016, 08:07 PM
  2. Fagor 8055T Restore from backup or cache?
    By Rembrandt in forum Fagor Automation
    Last Post: 05-03-2015, 10:51 PM
  3. Standard Modern 20 x 12 with Fagor 8050T
    By Bigbear8291 in forum Uncategorised MetalWorking Machines
    Last Post: 12-17-2014, 04:43 PM
  4. Fagor 8050T on Standard Modern 20 x 120 lathe
    By Bigbear8291 in forum Fagor Automation
    Last Post: 12-17-2014, 04:38 PM
  5. Help with my Fagor 8055T
    By Boxhead in forum DNC Problems and Solutions
    Last Post: 04-12-2012, 06:09 AM
