586,670 active members*
3,327 visitors online*
IndustryArena Forum > MetalWorking Machines > Tormach Personal CNC Mill > Deluxe Stand and Tormack 1100 and interference with holding fixtures
    Apr 2007
    4
    Question about Deluxe Stand and Tormack 1100
    1. How close to the column can the back edge of table on the Tormach go, is the minimum distance zero?
    2. With the Deluxe Stand what is the distance from the inside of the acrylic insert to the front edge of the table.
    I am trying to figure out what size vise will fit on the 1100 PCNC with the Deluxe Stand.
    Also it looks like the 8 inch rotary table motor would interfer with using the acrylic insert?
    David
    Jan 2007
    1332
    Here is a picture of a Kurt D688 http://www.kurtworkholding.com/workh.../anglock_d.php mounted on a Tormach. Overhang in the rear is ~1inch. The hex shaft protrudes though a 1.25” slot cut in the acrylic shield. The Kurt D688 has 6.8” opening. See:
    http://i72.photobucket.com/albums/i1.../PCNC_Kurt.jpg
    Don Clement
    Running Springs, California
    May 2007
    163
    Hi
    The vice dosn't hit the column in the back?
    Chris
    Jan 2007
    1332
    Quote Originally Posted by TT350 View Post
    Hi
    Chris
    The Kurt D688 vise protrudes about an inch out the rear of the Tormach table when using Kurt D50-33A step keys (11/16 x 5/8) http://www.kurtworkholding.com/acces.../vise_keys.php mounted in the center T slot. In this case the vise can hit the column when moving to the last inch of positive Y travel. IMO, the advantages of the Kurt D688 vise (e.g. 6” jaw width, 8.8” opening, GrooveLock® jaw http://www.kurtworkholding.com/acces...roove_lock.php ,etc) far outweigh the one inch loss of Y travel. I liked the Kurt D50-33A step keys (11/16 x 5/8) so much that I mounted a 5X7 angle table on ½” tooling plate with the vise keys mounted same as way as the Kurt vise. That way the vise and angle table can be easily interchanged and line up perfectly with X axis. Also the slot in the acrylic shield allows the vise to be loaded with the shield in place. see:
    Don Clement
  1. Flood Coolant Containment (Deluxe Stand)
    By SarcasmOMatic in forum Tormach Personal CNC Mill
    Last Post: 04-10-2007, 05:16 AM
  2. How Do You Like The Deluxe Tormach Stand?
    By Willyb in forum Tormach Personal CNC Mill
    Last Post: 01-31-2007, 04:38 PM
  3. Coolant for Tormach with deluxe stand?
    By MichaelHenry in forum Tormach Personal CNC Mill
    Last Post: 08-20-2006, 05:49 PM
  4. What do you think of the New Tormack PCNC-1100
    By Willyb in forum Benchtop Machines
    Last Post: 03-20-2006, 04:31 PM
  5. Workholding Fixtures
    By hstanki in forum Employment Opportunity
    Last Post: 03-06-2006, 07:35 PM
