586,052 active members*
4,210 visitors online*
    Dec 2018
    toolchange issues
    Hi
    We recently purchased a used mitsubishi mv5b with a meldas 520 control.
    On startup the control says tool 0 in spindle no matter what tool is actually in there. the other issue is tool changes, I call up a tool and the carousel doesn't move just changes what's there, after the tool change the carousel moves.
    Any help would be appreciated.
    Aug 2019
    Take all physicsel tools. And call some active tool number. now, give a tool to called tool number. And call another active tool. Now, your physcical tool in the Atc. Press jog and go to the behind the machine. What you see? A atc set buttons and small door. Now you do nc switch of. and open the door, press mag. index button. When the physically installed tool comes to you, enter the number and hold down the set key. Now you set that tool.
  1. Toolchange problem
    By armcoracing in forum Mastercam
    Last Post: 01-16-2011, 10:28 AM
  2. Toolchange
    By zooloader in forum Okuma
    Last Post: 11-04-2010, 08:48 PM
  3. VF0 toolchange Shuttle
    By lapokerplayer in forum Haas Mills
    Last Post: 08-25-2009, 02:32 PM
  4. eia toolchange issues
    By nestor82 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-28-2009, 05:23 PM
  5. 42/25 toolchange !!
    By mark1969 in forum Fadal
    Last Post: 01-08-2009, 03:51 PM
