586,102 active members*
3,106 visitors online*
Results 1 to 9 of 9
    Jan 2014
    6
    CNC Plasma 4x8
    Hello!
    I will present my build of a 4'x8' Plasma table. The mechanics is my own design and the electronics is a kit from CandCNC. It uses a Hypertherm Powermax 45 Plasma cutter.
    I have made a CAD model and building instructions which you can find here:
    https://grabcad.com/library/cnc-plasma-16
    The building instructions is also attached in this post
    Attachment 407394
    The mechanics consists of fixed AT5 belts, 25mm wide. The step motors is Nema 23 4,4 Nm (620 oz inch). With a 3:1 belt reduction(HTD3M belt) and a 15 tooth pulley on the AT5 belt, the motion is 25 mm per revolution of the step motor. This was the gearing recommended by CandCNC. The gantry weighs around 40 kg (excluding step motors). The linear bearings consists of TBR16 linear rail along the gantry and v-groove bearings for the gantry motion. The CNC software is Mach 3 on a windows xp computer.
    Sep 2005
    287
    Re: CNC Plasma 4x8
    Fantastic job Peter.
    Already have my table built but love to see a great set of plans to think about what I could have done better.
    Thanks very much.
    Jan 2014
    6
    Jan 2014
    6
    Re: CNC Plasma 4x8
    The X-axis wagon is attached on the gantry:
    Attachment 407728
    Attachment 407730
    The AT5 belt is attached:
    Attachment 407734
    The torch holder, mounted on the Z-axis:
    Attachment 407736
    Attachment 407738
    Attachment 407740
    Some testing of the electronics:
    Attachment 407744
    Jan 2014
    6
    Re: CNC Plasma 4x8
    Building of table for electronics, plasma etc:
    Attachment 407748
    Attachment 407750
    Attachment 407752
    Almost finished:
    Attachment 407754
    Attachment 407756
    magnetic torch breakaway:
    Attachment 407758
    Limit switches:
    Attachment 407760
    Attachment 407762
    Jan 2014
    6
    Jan 2014
    6
    Re: CNC Plasma 4x8
    Video of some cutting.
    Apr 2019
    We had a similar setup at our lab in university. It's beautiful job you did there.
    Oct 2020
  1. Modify Our CNC Plasma into High Definition Plasma and Brand New Electronics Motors
    By guy2b1 in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 01-21-2017, 11:37 PM
  2. Replies: 1
    Last Post: 01-01-2017, 09:58 PM
  3. Replies: 0
    Last Post: 09-25-2015, 07:37 AM
  4. Replies: 0
    Last Post: 12-13-2014, 06:27 PM
  5. Replies: 1
    Last Post: 08-05-2011, 08:21 AM
