586,036 active members*
3,921 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > How do I create an angled plane to create an angled slot in Alibre
    Oct 2018
    7
    Angry How do I create an angled plane to create an angled slot in Alibre
    Hi all Please can someone help me as I am losing the plot when I come to trying to use the planes function in Alibre, basic planes I can do but angled planes on a diameter I cannot!
    I need to machine a slot on a diameter at an angle of 45 degrees.
    I have attached a screen grab of the part.
    The angle is 45 degrees, and the angle starts at the bottom of the diameter and nearest to the front of the screen inclining back and away at 45 degrees cutting into the part. I have tried using the axis tool, but every time i use it I cannot get the correct details relating to the plane I need to use, to complete my task.
    Oct 2018
    7
    Re: How do I create an angled plane to create an angled slot in Alibre
    Hi all Please can someone help me as I am losing the plot, when I use the planes function in Alibre, basic planes I can use but angled planes on a diameter I cannot!
    I have attached a screen grab of the part see previous post.
    The angle is 45 degrees, and the angle starts at the bottom of the diameter and nearest to the front of the screen, inclining back and away at 45 degrees cutting into the part. I have tried using the axis tool, but every time I use it I cannot get the correct positioning relating to the plane I need to use, to complete my task.
    I hope I have explained this properly but if not please ask and I will be more descriptive.
    Apr 2016
    16
    Is this the sort of slot?
    What version of Alibre are you using?
    If you are using the latest version of Alibre Design (not Atom 3D) and it's what you are trying to do, I'll upload the file to my dropbox account for you to download and see what I've done.
    Nick.
  1. CNC Programming Z Axis Angled Slot Cut
    By Gene-Yo in forum G-Code Programing
    Last Post: 12-05-2011, 04:44 PM
  2. Help with angled slot!!!
    By dmitriy in forum G-Code Programing
    Last Post: 07-20-2011, 10:15 PM
  3. Replies: 12
    Last Post: 05-15-2011, 10:55 PM
  4. Using live tooling to create slot.
    By p8md in forum Okuma
    Last Post: 01-23-2010, 10:26 PM
  5. horn pin (angled pin)
    By spider in forum Moldmaking
    Last Post: 09-29-2007, 01:37 PM
