586,119 active members*
3,536 visitors online*
    Dec 2018
    11
    PlanetCNC TNG Slave Set Up
    Hello,
    In PlanetCNC TNG I am not able to set up a slave. I have attached the instructions, that states to just repeat the axis. Every time I go to put the second Y in, the first one disappears.
    Mar 2017
    1312
    Re: PlanetCNC TNG Slave Set Up
    Are you sure that you are doing this under File/Settings/Motors?
    Behavior that you describe is present under File/Settings/User Interface/Position
  1. Need help - wiring PlanetCNC Mk3/4 with 1.5kw VFD
    By billet works in forum Spindles / VFD
    Last Post: 03-29-2018, 07:13 PM
  2. Issues with PlanetCNC TNG
    By nucutza in forum PlanetCNC
    Last Post: 11-19-2017, 10:23 AM
  3. Planetcnc controller
    By go47f in forum PlanetCNC
    Last Post: 10-06-2017, 05:14 PM
  4. PlanetCNC DIY Controllers and TNG
    By ccandiotes in forum PlanetCNC
    Last Post: 08-01-2017, 10:28 AM
  5. PlanetCNC is on CNCZONE!!
    By PlanetCNC in forum PlanetCNC
    Last Post: 03-07-2017, 12:01 PM
