586,069 active members*
3,739 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask > Hello! 1994 Shoptask XMTC - modded
    Hello all! I've had my 1994 Shoptask 17-20 XMTC (the white one) for many years. I've upgraded a bit (Gecko540, Mach3, VFD motors, etc) and used it primarily as a CNC lathe with TECO L510 VFD and .75HP motor.
    More recently I decided to get the mill working and I have spindle related questions.
    On the mill side, I installed an identical TECO L510 VFD and a .75HP motor @ 1780RPM. This puts the spindle at about 2800rpm on my handheld tach.
    I'm used to milling aluminum at +5000rpm on a different machine (Tormach 1100PCNC) and am curious if the Shoptask spindle is safe to run above the 3000rpm mark. These are essentially tapered trailer bearings, so I'm not sure what they would be rated for.
    If I'm limited to 2800rpm, do you normally just adjust F&S with 2800rpm limit or are there any tricks for milling AL at slower RPM? More or less flutes? AL specific tooling?
    I'll post some photos if there's interest. I don't think it's too much more modded than the next guy's though.
    Thanks.
    -Rich
    Feb 2009
    152
    Re: Hello! 1994 Shoptask XMTC - modded
    The bearings on your machine are Timken numbers 7008X and 7007X tapered rollers. They are available in a variety of precision , heat and RPM ratings. I'm sure there is one that will suit your needs. Here is a link to the Timken engineering catalog
    https://www.timken.com/wp-content/up...ng-Catalog.pdf
    Apr 2015
    12
    rich...what motors did you end up going with nema 34?
    i purchased a cnc version of your machine...but the zed axis motor shaft was broken so im going to throw on a nema34...ill still use the molex connectors..
    mine came with the TMG Digital-CNC controller box.
    1993 technology...
    do you have any shots of your setup..
    any cool things you have made with it?
    i was also thinking of upgrading the lather and mill motor to dc...
    with speed control instead of a vfd.
    is the vfd you bought working well>
    do you have the lather and mill working off the same vfd?
    sorry for all the questions
    hmmm
    merry xmas
    Quote Originally Posted by SupraRich View Post
    Thanks.
    -Rich
  1. Shoptask 1720 XMTC parts
    By techsol in forum Shopmaster/Shoptask
    Last Post: 03-30-2022, 04:49 AM
  2. just bought a shoptask 1720 XMTC
    By RAYJAY in forum Shopmaster/Shoptask
    Last Post: 04-05-2016, 11:00 PM
  3. Looking for gearset for Shoptask XMTC 1720
    By jt69 in forum Shopmaster/Shoptask
    Last Post: 01-29-2012, 08:46 AM
  4. ShopTask 17-20 XMTC Parts ID Help (W/PICS)
    By LX Kid in forum Shopmaster/Shoptask
    Last Post: 11-27-2011, 07:33 AM
  5. Shoptask 1720 XMTC add CNC
    By mustangdug in forum Shopmaster/Shoptask
    Last Post: 11-30-2010, 12:07 AM
