587,513 active members*
3,030 visitors online*
    May 2006
    South Bend CL2CT
    Does any one know anything about these or even better used one before.
    I found this one for $1,600.00 and wanted to see what input you might have as to weather or not it's a good deal etc.
    http://www.annexrecording.com/lathe.jpg
    Thanks for any input you might have.
    Jonathon
    dcencer Guest
    Looks great to me, unless the paint is actually a bad repaint job. The picture is too small to determine that. Check to see if the spindle bearings have discernable side play, and run the motor through all the speed ranges.
    Oct 2005
    278
    Thats a very nice lathe.
    I own 2 10"southbends at this moment.
    but i'm not sure this is the correct forum cause you absolutely positively never want to retro this lathe in to cnc controls.
    Google for machinist southbend and first hit should contain more then you'll ever wanna know about this lathe. I'm sure you'll like it f you're a hobbyist.
    have fun.
    (ad, i hope i was politicly correct in my directions)
  1. South bend Magnaturn CNC Problem
    By JJKPGZ in forum Uncategorised MetalWorking Machines
    Last Post: 11-29-2023, 06:10 PM
  2. Help with South Bend Magnaturn CNC lathe
    By Fudd in forum South Bend Machinery
    Last Post: 12-12-2020, 03:40 AM
  3. Looking for someone to bend parts!
    By CoolhandLuke in forum Bending, Forging, Extrusion...
    Last Post: 02-21-2007, 04:03 AM
  4. Bend-Tech-ez
    By diarmaid in forum Mechanical Calculations/Engineering Design
    Last Post: 09-23-2006, 05:19 PM
  5. ? Correct South Bend Paint Colour ?
    By vladdy in forum Uncategorised MetalWorking Machines
    Last Post: 11-08-2005, 09:09 AM
