586,072 active members*
4,634 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > 1996 4020ht - new to me, much maintenance required
Page 1 of 3 123
Results 1 to 20 of 54
    Jan 2010
    321
    Just picked up a 1996 4020 with 28inch z axis.
    We brought it without been able to power it up but the price was right so worth the punt.
    The good
    Ways look good
    Electrically runs fine
    1400-5 cpu (upgraded according to the parameter sheet ment to have 1400-4)
    -5 axis cards
    Turcite on x axis looks good from the little I can see.
    The bad
    Hasn't been running for near 3 years
    Backlash numbers are high z=20 y=25 x=30
    After running a dti along the screw I have z.02mm x0.05mm y0.025mm thrust bearings and couplings require replacement and/or inspection.
    Y thrust bearings are noisey as and you can feel them through the table so need to be replaced.
    Spindle is very noisey just trying to track down if it is coming from the spindle (likely) or the motor(unlikely)
    The spindle chiller has been completely disconnected.
    55k power on hours
    18k cutting hours
    The plan of attack
    First thing is the replace the y axis thrust bearings and coupling then remeasure backlash. Hopefully the numbers will drop considerably. Then move to the other 2 axis.
    Does anyone have any tips for thrust bearing replacement especially y axis as that will be the first on the list.
    Cheers
    Oct 2008
    1632
    Re: 1996 4020ht - new to me, much maintenance required
    You can order the thrust bearing and seal kits from several sources like ITS or FadalCNC for around $90 per axis.
    The ones I just got from ITS were NSK bearings and had the preload shim with the kit, and all the required seals.
    I just did all mine this week and it's pretty simple, especially for me because I removed all my screws to be reworked so my bearing carriers were already off.
    Just make sure the thrust bearings are face to face, in other words, the thick side of the inner races will face each other. The shim goes between the faces.
    Make sure you get the correct kits. There is one from metric screws and then inch screws. With yours being a 1996 I would imagine they are metric.
    Richard
    Jan 2010
    321
    Cheers.
    We are in Australia so getting gear from the states is time consuming and costly. Will pull it apart and try to source parts locally.
    Can the bearings be replaced without pulling the bearing block off?
    My screws need attention also. What did you get done to yours? A reball or replace?
    Jan 2010
    321
    After removing the y axis servo , coupling and mount I can't for the life of me undo the nut that holds the thrust bearings.
    Looks like I am about to do what I never thought I would and that is take an impact gun to the ball screw
    Oct 2008
    1632
    Would you like the numbers for the metric bearings and seals? I still have the boxes. You could probably reuse your old shim.
    I also used an impact to remove the stop nuts on the end of the screws. I used short quick burst and they came right off.
    On the ball screws and nuts, it's supposed to be a total rework. Regrind and rebuild.
    They guarantee, it will be as good or better than new. I guess we will see how good of a job they do.
    Jan 2010
    321
    That would be great thanks. Part numbers are gold.
    Impact gun it is .
    Cheers
    Oct 2008
    1632
    3 of SKF Seals 12360 (Inside block coolant seals)
    1 of SKF Seal 11138 (Seal for thrust retainer to screw seal adapter)
    2 of NSK Angular Contact Bearings 7304BYGUG2 - NB5F 20mm x 52mm x 15mm
    1 of preload shim 0.875" ID x 1.375" OD x 0.001" thick
    Jan 2010
    321
    Bloody champion thanks
    Jan 2010
    321
    Seems the bearings are ex production so no stock within nsk worldwide.
    Looks like they will need to come from the states or I can change to a proper ball screw support bearing and go away from the angular contact but they are pretty expensive at about $200 a bearing.
    Will shoot off an email to the fadal parts places and see what shipping cost and time I can expect and make my decision from there.
    Apr 2014
    345
    Quote Originally Posted by Deano7/11 View Post
    I order them from Misumi for very cheap. They do international shipping I’m pretty sure. Any 7304 bearing should work.
    Jan 2015
    417
    Download for free All Fadal Manuals do not pay for them several places https://flintmachine.com/fadal.php or Fadal Manuals | ItsCnc.com parts manual, maintenance, troubleshooting etc. etc.
    Jan 2015
    417
    Oh and by the way many of the small components (belts, air valves , relays etc.) on the fadal can be bought from https://www.mcmaster.com/
    Jan 2010
    321
    Cheers guys.
    Pulled the y axis off.
    Just had regular 7304 bearings in it with something that may have looked like a shim many years ago.
    I will get some regular 7304 and see how the axis comes up.
    The old bearings were very stuffed.
    The issue with international freight is the cost. One axis bearing rebuild kit is something like $120usd in freight 3x kits is $250usd freight.it is hard to stomach.
    If I need 3 axis kits 3 x ball screws and a spindle the freight for all that is about 3kusd that is a bit over 5k of our money. Nearly double the cost of the machine.
    I would be better off getting it sent to a address in the states and buying a $800 return tix and flying over to the states and bringing it all back as carry on and stowed luggage.
    Re manuals. I have a couple of sets. Thanks for the tip tho.
    Apr 2014
    345
    Cheers guys.
    Did you look at misumi bearings are like $20 each and I’m pretty sure freight will not be that much. I believe they carry the seals and shims aswell but I’m not sure.
    Also I’m about to order some bearings if you want I can add some to my order and ship it to you if there’s no other option. Nsk bearings run me $15 each. It won’t be cheap to ship but probably won’t be $250. The seals are easy to find skf 11138 seals but I can send those aswell.
    The bearings could be any brand you can get they just have to be 7304 b. See if someone local has them.
    Jan 2010
    321
    Quote Originally Posted by ianagos View Post
    Cheers mate.
    Yeah 7304b are very available here for stuff all. Seals are also plentiful so no issue there. Will grab some next week from the bearing supply and reassemble the axis. I have some .002 shim so will throw some of that in and see what we end up with.
    Ballscrews can be specially ordered from many manufactures so might make a note of the size and end machining and get a quote. They take 6 weeks to get made but ones I have had made previously came up great.
    They are a double nut style c1 from memory grade ground screw.
    As for couplings I am replacing them as well. They are 5/8 on the screw and 7/8 on the motor. Was going to use a flex disc style.
    Jan 2010
    321
    Cheers mate.
    Attached is the coupling I want to use
    Oct 2008
    1632
    Deano7, Those numbers will cross to parts available anywhere. Nothing special. Just type in the seal numbers or the 7304.
    If you can get the 0.001" shims, you may have to double them up. Start with one and see if the preload is satisfactory or not then add another if you need to.
    The ballscrew vendor I went with keeps pushing my ship date out. They have to regrind the screws on the Y and Z. I'm anxious to get mine going. Maybe next week!
    Cheers guys.
    Oct 2008
    1632
    Check around, there should be plenty of places there that can rebuild your screws for 50% the cost of a new one! I good quality place can actually regrind them to a better spec than available back in the 90's.
    Double Nut? Really, or double circuits? All mine were single nut with double circuits and were factory NSK and Century screws.
    Cheers mate.
    Jan 2010
    321
    Not sure if we have those facilities here in oz.
    There are people that can rebuild the screws but not sure about a regrind.
    I will do some further investigation next week
    Jan 2010
    321
    After further investigation the x axis screw has 0.1mm backlash in it so it needs replacing.
    Question is what is the procedure to remove the screw from the bottom of the table?
    I have the way covers off but it is a look way under. I jogged the table to one side and removed the cover under the table and can access a little bit but pretty bloody difficult.
    Surely I don't have to take the table off?
    Maybe remove thrust bearing plate and support bearing and push the table past it standard travel???
    Any ideas ?
Page 1 of 3 123
  1. topless 4020HT
    By thomasz in forum Fadal
    Last Post: 09-19-2011, 10:48 AM
  2. 4020HT metric or not?
    Last Post: 08-06-2011, 03:16 PM
  3. 4020HT - question
    By MBX5 in forum Fadal
    Last Post: 08-20-2010, 06:17 PM
  4. Help required with Mazatrol 640 Maintenance Text.
    By piper468 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-23-2009, 04:38 PM
  5. Looking for a use 4020HT with rigid tap
    By REVCAM_Bob in forum Fadal
    Last Post: 05-13-2006, 07:50 PM
