586,102 active members*
2,970 visitors online*
Results 1 to 13 of 13
    Nov 2006
    61
    Z8350 with UC300ETH and UB1
    Time changes everything. Here it comes, a small footprint all-in-one mini PC which able to run Mach3 and UCCNC. It takes a small CPU resource. The price of this PC is around 100usd include Windows 10.
    Weerasak.
    www.CNCRoom.com
    Nov 2006
    61
    Re: Z8350 with UC300ETH and UB1
    Pull apart
    Weerasak.
    www.CNCRoom.com
    Jun 2018
    362
    Do you have full specifications and availability?
    HarryE.
    Nov 2006
    61
    I purchased it from Shopee online store in Thailand. I believe you can buy it in your local online store also.
    https://shopee.co.th/Z85-Z-8350-2-GB...713.1604291030
    Here is the specification.
    Z83 II Intel Atom Mini PC 4K UHD
    -Win 10 64bit System
    -2GB DDR3+32GB eMMC
    -Intel Atom x5-Z8350
    -Intel HD Graphics 400 Desktop PC
    -USB3.0 USB2.0 HDMI Double Wifi 1000Mbps/LAN BT4.0
    Weerasak.
    www.CNCRoom.com
    Jun 2015
    943
    Nice. What machine is it?
    Do you have more videos of it?
    Nov 2006
    61
    It is fixed column CNC milling for soft metal cutting. We designed and made it for our own use.
    We prefer big bathtub rather full cover. This helps to collect splash cutting oil back to pump. It also collects cutting chip or prevents fly away chip.
    This topic is intended to show current Atom technology which related to CNC things.
    Weerasak.
    www.CNCRoom.com
    Does UCCNC run good on it?
    Jun 2015
    943
    Quote Originally Posted by vrasak View Post
    Thanks Vrasak, I see that this thread is about the computer, but I was interested in the machine details also.
    Do you run UCCNC also on that Atom computer? Any videos? It would be interesting to see if it runs well, then I might buy one.
    Nov 2006
    61
    I tried this mini PC with UCCNC on the first day when received this PC. Since then I don't have a chance to try it with UCCNC again.
    It seems that the Windows 10 keep updating or adjusting itself for the first few hours. The video shows that the CPU graph is jumped up and down before I start UCCNC software. I believe that UCCNC wouldn't consume much CPU time. However, I will check and confirm it again.
    Weerasak.
    www.CNCRoom.com
    Apr 2014
    59
    Is that .Net package good for Win10? On Win8 or Win10 you should install .Net 3.5 in the "Turn Windows features on or off" window by selecting .Net 3.5. Just press Start and type "optionalfeatures". It will download the proper package.
    Jun 2015
    943
    Quote Originally Posted by dezsoe View Post
    I did not know, just found this video that UCCNC can run on a cheapo mini PC like the lattepanda?! hmmmm
    Nov 2006
    61
    Thankyou, I will do it properly
    Quote Originally Posted by OlfCNC View Post
    It seems to me, we are living in a strange world. Because I thought that LattePanda is using ARM CPU. However, after searching and found that it's using the same CPU Intel Cherry Trail Z8350 and run on Windows 10.
    https://www.lattepanda.com/products/1.html
    Weerasak.
    www.CNCRoom.com
    Jun 2015
    943
    I thought the same that it has ARM CPU.
  1. UB1 + UC300ETH wiring
    By spumco in forum UCCNC Control Software
    Last Post: 09-12-2018, 12:09 AM
  2. UC300ETH-UB1?
    By KurtRosenzweig in forum Chinese Machines
    Last Post: 06-23-2018, 01:30 PM
  3. UC300ETH BOB
    By Nissen in forum CNC Machine Related Electronics
    Last Post: 04-15-2018, 02:25 PM
  4. UC300ETH not connecting
    By Andrew22 in forum UCCNC Control Software
    Last Post: 03-20-2018, 11:40 PM
  5. UC300ETH-5LPT Supplier
    By Tim_DGE in forum South Africa Club House
    Last Post: 02-23-2018, 05:05 PM
