586,630 active members*
2,468 visitors online*
    Mar 2018
    68
    idlers and shaft support
    I'm wondering if supporting both sides of a shaft is the best way to go or if using an idler bolt or relying on the motor bearings better. It seems that unsupported idlers are very common in 3d printers and on drive pulleys for belt reduction on cnc machines. Is cost the main reason the shaft is supported on only one side?
    Jun 2011
    692
    Re: idlers and shaft support
    Usually supporting a pulley shaft from both sides traps the belt, making service a pain.
  1. Replies: 0
    Last Post: 07-27-2013, 06:44 AM
  2. How is a shaft attached to a shaft support rail ?
    By Power_user_EX in forum DIY CNC Router Table Machines
    Last Post: 06-16-2012, 12:03 PM
  3. shaft support bearing placement
    By dsc in forum Mechanical Calculations/Engineering Design
    Last Post: 11-29-2009, 10:53 PM
  4. shaft support
    By smarbaga in forum Mechanical Calculations/Engineering Design
    Last Post: 04-17-2005, 02:58 AM
