586,094 active members*
4,030 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Connecting Dela MS300 VFD to my machine.
    Jan 2013
    228
    I have my new Delta VFD MS300 series (manual here: Services & Support - Download Center - Delta Group). I have the motor parameters entered in and the spindle is starting/stopping nicely. (Haven't cut with it yet).
    I have a few questions regarding set-up. I am trying to configure one of the digital outputs to trigger when The spindle is up to running speed. I am trying to set MO1 to do this.
    My current configuration:
    Accel (1-12) set to 5.
    MO1 (2-16) set to 2.
    0-10V input on AVI
    What is happening with this setting is that as soon as the spindle starts to rotate MO1 triggers.
    I tried setting 2-16 to 3 and 2-22 to 200Hz, but it only triggers briefly when it hits 200HZ (As I thought it would)
    Some more about my system. I am using an ESS (Smooth stepper) for the control board, and Mach 4 for the front end.
    The second issue I am having is that after cycling power I need to press the "Run" button once in order for the vfd to respond to the commanded speed. I would like to set it so that I don't have to do this, opening the cabinet each time I power up the machine would be a pain.
    15362
    Re: Connecting Dela MS300 VFD to my machine.
    Quote Originally Posted by TTalma View Post
    0-10V input on AVI
    Have you set Parameters for remote control it sounds like you still have partial Keypad control
    Mactec54
  1. Cnc machine power wire connecting 220v and 380v
    By allencncrouter in forum Videos
    Last Post: 12-19-2018, 02:31 AM
  2. Connecting it all
    By robart in forum CNC Machine Related Electronics
    Last Post: 11-03-2017, 07:47 PM
  3. Connecting C6 to C35
    By Thomasn in forum CNC Machine Related Electronics
    Last Post: 02-04-2013, 09:20 PM
  4. Connecting to CNC from PC
    By Jake E. in forum Computers / Desktops / Networking
    Last Post: 01-04-2013, 10:52 PM
  5. Connecting CNC machine to Mach 3
    By JackWilliam in forum Mach Software (ArtSoft software)
    Last Post: 11-19-2012, 11:56 AM
