586,077 active members*
3,938 visitors online*
    Jan 2019
    Question What Software contoller to use
    Hello guys ,
    I just bought a used Chinese laser machine. I am looking for a solution to turn it on.
    the problem is that I dont know the software to control it.
    I tried .plt .dxf .ai files directly with a flash drive but it does not work.
    the machine is well connected to my computer and the drivers are well installed.
    the driver is Yako Driver "YKA2304ME".
    also, i found some .out files in it's intern memory and that works perfectly.
    I do not know if there is a universal software that runs this kind of laser machine.
    please help me and thank you in advance
    Aug 2018
    28
    Re: What Software contoller to use
    Hi M-Wael
    You need to verify which controller you have installed. The most common Chinese controllers are: Leetro and Ruida.
    If you have a Leetro controller, the software you should use is LaserCut. The file format is .mol for download from a flash drive.
    If you have a Ruida controller, the software you should use is RDWorks. The file format is .rd for download from a flash drive.
    Good luck and Best regards
    we are:
    BuchiCNC USA
    You can check our CO2 laser cutters here:
    CO2 Laser cutting machines
    If you want a metal laser engraver:
    Laser metal engravers
    Great CNC Router:
    CNC Routers
    Soy tecnico de laser con experiencia.<br />Usuario de maquina de corte laser Buchicnc EVO 14.<br />Usuario de grabadora laser por fibra EVO 5.<br />Usuario de router CNC, con mesa de 3 x 2 mts Auto Tool Changer<br />Diseño mis propios archivos maquinas de corte laser con CorelDraw, LaserCut 5.3, RDWorks V8.<br /><a href="https://buchicnc.com" target="_blank">Estas son mis maquinas de corte láser BuchiCNC</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-14/" target="_blank">EVO 14</a><br /><a href="https://buchicnc.com/producto/maquina-de-corte-laser-evo-5/" target="_blank">EVO 5</a><br /><br /><a href="https://buchicnc.com/en/" target="_blank">Laser cutters &amp; CNC Routers BuchiCNC USA</a><br /><a href="https://buchicnc.com/en/product/cnc-router-mr-atc-6-standard-line/" target="_blank">CNC Router ATC</a><br /><a href="https://buchicnc.com/en/product/laser-cutting-machine-evo-14/" target="_blank">EVO 14</a>
    Apr 2022
    24
    Depending on the brand and type of controller in your machine, you can use a variety of software. However, before we further understand, we need to distinguish between laser design software and laser control software. They are usually used in pairs, but they are designed to do different things. Laser design software is used to create graphics, which can be cut on the laser cutting machine in the future. CorelDRAW, Inkscape and Adobe Illustrator are among the most popular products. Laser control software (called cam in the CNC world) is used to convert graphic design into a set of commands, which can be understood by the laser controller and then converted into a coordinate list. https://monportlaser.com
    The following is a list of the most commonly used laser software for laser cutting. We made a simple comparison to show its advantages and shortcomings. https://monportlaser.com/collections/products
    Industrial Co2 Laser Engraver & Cutter offer- RDWorks
    Industrial Co2 Laser Engraver & Cutter Compatible Software - LightBurn
    Final Thoughts
    Different manufacturers use different laser controllers for their engraving machines. The type of controller will limit the options for which software you can use to communicate with these controllers. However, if you know more about the software with different functions, you will not be limited by the software that comes with the machine. I hope this article can help you choose the software suitable for your machine. Our Monport official website also provides the software suitable for most laser engraving machines. If you need it, you can click here to buy it.
  1. Fusion360 Post for C-Tek CNT-830 Contoller
    By metalnut in forum Autodesk Post Processors
    Last Post: 03-18-2018, 09:17 PM
  2. TB6560 and DC Spindle with PWM contoller
    By acuralegendz in forum Spindles / VFD
    Last Post: 01-01-2014, 07:04 PM
  3. Hurco BMC 30D contoller manual
    By Dafish in forum Machinery Manuals / Brochures
    Last Post: 04-16-2013, 06:47 AM
  4. Contoller PC
    By oknups in forum Tormach Personal CNC Mill
    Last Post: 02-03-2012, 11:45 PM
  5. anilam contoller
    By barnesy in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-29-2006, 10:30 PM
