586,108 active members*
3,175 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > How to add Dwell to allow drill to cool down, 30 deep holes in perspex?
    Dec 2011
    6
    Hello,
    I am hoping some kind person can please help me? I want to drill 30off 10.3mm dia holes, 22mm deep into cast perspex and I suspect that the drill will overheat and wreck the job. How can I add a dwell of say 20 seconds after each hole to allow the drill to cool down before the next hole?
    This is the Code I want to use..(with no dwell)....My machine is a Chinese router with a 2.2KW, 24K spindle and has very little torque if going too slowly.
    (DRILL2)
    M5
    M9
    M1
    T4 M6
    S2000 M3
    G54
    M9
    G0 X76.5 Y-34.
    G43 Z25. H4
    Z10.
    G83 X76.5 Y-34. Z-22. R1. Q3. F200.
    X59.5
    X42.5
    X25.5
    X8.5
    X-8.5
    X-25.5
    X-42.5
    X-59.5
    X-76.5
    Y0.
    X-59.5
    X-42.5
    X-25.5
    X-8.5
    X8.5
    X25.5
    X42.5
    X59.5
    X76.5
    Y34.
    X59.5
    X42.5
    X25.5
    X8.5
    X-8.5
    X-25.5
    X-42.5
    X-59.5
    X-76.5
    G80
    Z25.
    G28 G91 Z0.
    G90
    Thanks in advance
    Simon
    Apr 2005
    304
    Re: How to add Dwell to allow drill to cool down, 30 deep holes in perspex?
    You can edit this g-gode in a notepad and add dwell after each drilled hole:
    (DRILL2)
    M5
    M9
    M1
    T4 M6
    S2000 M3
    G54
    M9
    G0 X76.5 Y-34.
    G43 Z25. H4
    Z10.
    G4 P20
    X59.5
    G4 P20
    X42.5
    G4 P20
    X25.5
    G4 P20
    X8.5
    G4 P20
    X-8.5
    G4 P20
    X-25.5
    G4 P20
    X-42.5
    G4 P20
    X-59.5
    G4 P20
    X-76.5
    G4 P20
    Y0.
    G4 P20
    X-59.5
    G4 P20
    X-42.5
    G4 P20
    X-25.5
    G4 P20
    X-8.5
    G4 P20
    X8.5
    G4 P20
    X25.5
    G4 P20
    X42.5
    G4 P20
    X59.5
    G4 P20
    X76.5
    G4 P20
    Y34.
    G4 P20
    X59.5
    G4 P20
    X42.5
    G4 P20
    X25.5
    G4 P20
    X8.5
    G4 P20
    X-8.5
    G4 P20
    X-25.5
    G4 P20
    X-42.5
    G4 P20
    X-59.5
    G4 P20
    X-76.5
    G4 P20
    G80
    Z25.
    G28 G91 Z0.
    G90
    Or G4 P20000 if dwell time is set in milliseconds.
    Make no mistake between my personality and my attitude.
    My personality is who I am. My attitude depends on who you are.
    Dec 2011
    6
    Thank you very much ZASto.....exactly what I needed to know. :-)
  1. Drill holes at an angle in superalloy....and deep too
    By gogego in forum Hard / High Speed Machining
    Last Post: 11-25-2015, 10:50 PM
  2. Drill with dwell
    By Darth Yoda in forum BobCad-Cam
    Last Post: 01-31-2013, 12:32 AM
  3. Replies: 8
    Last Post: 01-25-2008, 04:12 PM
  4. drill dwell between holes
    By EVERFABCHAD in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-11-2006, 01:15 PM
