603,415 active members*
2,765 visitors online*
    pcut and r510a
    When cutting just a circle, it seems that pcut can cut the circle with a g02, but cannot cut with g03. Sometimes it cannot cut with the g02 but will with the g03. It seems it has something to do with what direction it has approched the circle with. Also, when the torch height control is used, a high voltage value (which indicates that the flame is to long) drives the z axis motor in the wrong direction. Anyone else notice this. I have tried to ask Vlad, but seem to get ignored.
    David Paulson.
    D. Paulson
    May 2004
    4
    pCut have bug prone architecture so strange things like this can happen quite often. Be careful on what CPU you are running pCut, the faster CPU you have than the communication with board will be more unstable (bugs in time dealy code).
