586,089 active members*
3,819 visitors online*
Results 1 to 8 of 8
    Dec 2006
    87
    Mesa Card Help
    Hi guys,
    Need a lil help understanding the mesa card.. specifically the "D" card my confusion is in the 24 volt portion ... one provides 24 volts for all the ancillary options and one provides the ground ?
    maybe it was just the way it was explained to me
    thanks in advance
    Joe
    Feb 2008
    644
    Re: Mesa Card Help
    Which mesa card do you have?
    Dec 2006
    87
    Re: Mesa Card Help
    i have not purchased it yet but im looking at one of the plug and go kits possibly the 7I76-5I25 PLUG-N-GO KIT
    Dec 2006
    87
    Re: Mesa Card Help
    im looking to outfit 2 bridgeport machines 4 axis maybe 5 with auto oiler fog buster coolant maybe spindle speed control via vfd
    and a lathe 2 axis with vfd spindle speed control and fog buster coolant control
    Feb 2008
    644
    Re: Mesa Card Help
    If you are asking about the 7I76/7I76 D difference, the only difference is that the 7I76 has sourcing field I/O outputs and the 7I76D has sinking outputs
    That is the 16 7I76 field outputs source +12 or +24V to the load (so the load common is power supply common):
    7I76 output --> relay coil --> common (or ground)
    The 16 7I76D field outputs are sinking so load common is +12 or +24V:
    +24V --> relay coil --> 7I76D output
    Dec 2006
    87
    Re: Mesa Card Help
    thanks, yes that is what im confused about.. so the 7i76 outputs 12 or 24 volts to the relay and thats what triggers the relay to make the connection from the 12 or 24 volt main powersupply to the peripheral ?
    Feb 2008
    644
    Re: Mesa Card Help
    Yes, if you think of the 7I76/7I76D outputs as switches, the 7I76 has a common +12/+24V for all 16 "switches" and the 7I76D has a common negative (ground) for all switches
    Dec 2006
    87
    Re: Mesa Card Help
    thank you for that information !
  1. Mesa 5i25 card - Low price
    By district7 in forum For Sale Only
    Last Post: 08-21-2017, 12:48 AM
  2. Mesa card not detected by PP
    By zardozwildman in forum Tormach PathPilot™
    Last Post: 02-20-2016, 05:02 AM
  3. Mesa Card Jumpers
    By BAMCNC.COM in forum Tormach PathPilot™
    Last Post: 11-29-2015, 02:50 AM
  4. Mesa 5i20 PCI card
    By karl1 in forum CNC Machine Related Electronics
    Last Post: 03-06-2010, 06:17 PM
  5. using VSD-A with mesa anythingio card
    By daedalus in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-04-2007, 01:08 AM
