Hello everyone
I'm new to CNC machining and I was looking into buying a new CNC machine for metal work, steel mainly, I digged a bit and ended up buying a chinese CNC Machine
The 6090 PRO, https://www.ebay.com/itm/CNC-6090-Ro...LI6U:rk:4:pf:0
It was advertising as a milling machine that's capable of cutting all kind of metals, you can see the details in the link above but that's not where I got it from
After getting it to run and testing it on wood, I tried cutting aluminum manually and it seems to struggle doing that
Has anyone tested this machine before?
Is there a machine you recommend for such purpose?
I'm aiming for milling steel bars on 4 axis
Thank you![]()
