586,036 active members*
3,532 visitors online*
IndustryArena Forum > Material Technology > Hard / High Speed Machining > Variable Programming - Critique My Code, Please
    Sep 2015
    17
    I've attached the blueprint of the part to be made and my code to machine the 5 slots in the OD. My goal is to have a program that regardless of the tool diameter, programmed radius or # of passes/DOC can be changed with relative ease. I'd like to make #527 passes where each pass is #528/#527 deep (the actual DOC is [#528/#527]/2 because the Y axis is diametrical).
    I've never used variables to this extent so I'm hoping y'all will look it over and critique my code.
    In the program I accounted for the key cutter tool radius when I programmed the tool path, so the R value on the offset screen=0.
    I'm cutting on the minus(-) side of Y0.
    Thanks in advance!
    Attached Files Attached Files
    Jun 2015
    4154
    Re: Variable Programming - Critique My Code, Please
    hi, if you are still intersted into this, i may try to help ... but i can't download the code, and i can't see the picture, so re-post them if you wish / kindly
