586,207 active members*
4,001 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2) > upgrading from flashcut software to linuxcnc with gecko drives timing issue
Results 1 to 9 of 9
    Jun 2009
    195
    I'm in the process of configuring linuxcnc with gecko 320x drives and the motor is only moving in pulses . the motor steps per rev are 512 and encoder divisions is 10 . I think that acts like drive microstepping . Its been a while I've played with this stuff and am a little rusty . Any ideas as to ware I'm going wrong ?
    Apr 2004
    5738
    Re: upgrading from flashcut software to linuxcnc with gecko drives timing issue
    10 divisions per revolution is very coarse for encoder counts. Normally, there would be about 250 counts per rev. or more. The motors used with Gecko 320-series drives don't have steps; those drives are used with brushed servo motors. So it wouldn't be microstepping - are you sure the encoders don't have 512 lines on them? (You can usually open the covers and peek without damaging anything.) Servo motors typically have a bunch of skinny wires going to the encoders, but only two fat ones that run them. Steppers will have 4, 6 or 8 wires driving them, but encoders aren't often used.
    Andrew Werby
    Website
    Jun 2009
    195
    I'm running 3 DC servos and 1 stepper . Here is my flash cut config scream shot . The drivers are going into fault . I tried increasing the gain but that's not it .
    Sent from my SM-G965U using Tapatalk
    Does that mean 10 x 512??
    Jun 2009
    195
    Its ten encoder ticks to one pulse to move . So its 10 divided 512. It ran ok under flash cut. I just need more functionality in my software .
    Jun 2009
    195
    So micro stepping is 100th the steps per rev ? That gives smooth movement.
    Apr 2004
    5738
    From your chart, it looks like the stepper is set to half-stepping (2 microsteps per step). That's going to give you the best torque and accuracy, but it doesn't smooth out resonance as much as higher microstepping counts do. The servos have an index pulse, which fires every 10 encoder counts. But it should be moving on the encoder signals, not just on the index pulses.
    Andrew Werby
    Website
    Jun 2009
    195
    Thank you Andrew I will change that when I get in . The next fun is configuring my A axis that is a stepper drive . I searching for info on that now .
    Jun 2009
    195
    It doesn't like micro steps above 1 . So .512 and half that works . Distance is .005" off moving .02" @.256 ms
  1. Anyone with experience from DYN4 drives and LinuxCNC?
    By nschmidt in forum Dmm Technology
    Last Post: 05-29-2019, 06:14 PM
  2. Viper 200 Servo Drives with Linuxcnc
    By CATCH22 in forum Viper Servo drives
    Last Post: 05-21-2016, 10:00 PM
  3. upgrading drives and c code
    By turbothis in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-27-2013, 03:46 AM
  4. NEED HELP FOR RTA PAVIA SDC 05 DRIVES TIMING
    By radzuan in forum Community Club House
    Last Post: 05-22-2011, 05:06 AM
  5. MAXNC software with gecko 202 drives
    By ajitsingh in forum Mach Software (ArtSoft software)
    Last Post: 08-10-2006, 04:57 PM
