586,121 active members*
3,643 visitors online*
    Oct 2010
    670
    Probing Routine Using ITTP
    Probing routine out of Fusion 360. I have the ITTP from https://hallmarkdesign.co.nz/probe and want to set up a probing routine at the start of each part for a second operation. Basically I need to validate and reset G54 due to the part being flipped over and there being some slight +/- variables from OP 1. When I try to CAM it out in Fusion 360 the post fails. Anyone doing this?
    Tormach 1100M w/ the ITTP probe
    This is what post out (cannot find the "log" it's talking about).
    (OP 2)
    (T99 D=0.156 CR=0.078 - ZMIN=-0.3987 - probe)
    G90 G54 G64 G50 G17 G40 G80 G94 G91.1 G49
    G20 (Inch)
    G30
    N10(Probe1)
    T99 G43 H99 M6
    (ITTP Probe)
    M5 M9 (SPINDLE IS OFF)
    G54
    G0 X0.5625 Y0.2779
    G0 Z6.2
    G30
    M30
    !Error: Failed to post data. See log for details.
    The Body Armor Dude - Andrew
    Jul 2016
    140
    Re: Probing Routine Using ITTP
    You're getting the error because the Fusion post for PP doesnt support probing. https://f360ap.autodesk.com/courses/...behind-probing
    Tormach PCNC 1100 Series 3 w/ Rapid Turn, Fusion 360
    Oct 2010
    670
    Quote Originally Posted by sharmstr View Post
    Wow! That's some pretty deep macro stuff. Guess it'll be manual mode for now! Thanks for your help and direction!
    Aug 2009
    42
    G'day,
    I've modified the Fusion360 Tormach post to give some basic probing functionality by adding a keyword to the comments. Based on that, the post adds some macros to the resultant gcode file. You can get the post from my website: http://www.kunstmade.com.au/CNGTorma...PostAddv11.zip
    There's a bunch of other stuff in the post:
    - email sending at tool change and program completion
    - workpeice size calculation
    - tool max depth calculation
    - date and time of gcode generation added
    - adds the fusion setup name to the gcode
    - writes tool description table
    - writes setup notes
    The readme file in the zip file has the details.
    Regards, Christian
    Apr 2011
    720
    Christian, thanks very much for your work. This looks like it will be really fun to explore!
    Terry
  1. Help with probing routine
    By kdunph33 in forum Haas Visual Quick Code
    Last Post: 09-05-2019, 06:49 PM
  2. Probing Routine - Haas/Renishaw
    By amphib in forum G-Code Programing
    Last Post: 04-28-2018, 01:35 PM
  3. Fast Probing Routine/Wizard/Setup?
    By Bob La Londe in forum Digitizing and Laser Digitizing
    Last Post: 06-30-2013, 05:14 AM
  4. Heidenhain Probing Routine
    By nigel2000 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-22-2012, 01:50 PM
  5. A better JOG routine
    By Karl_T in forum CamSoft Products
    Last Post: 04-01-2011, 01:59 AM
