586,075 active members*
3,678 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > V carve tool path limit?
    May 2013
    60
    Trying to bid a router job so I vectorized the art and tried to create a tool path. If I select a small portion of the vector art a tool path is created BUT if I select it all, no tool path is created. Have I exceeded some limit in BobCAD v27?
    Attachment 411894
    Dec 2008
    4548
    Quote Originally Posted by twoclones View Post
    I doubt it. It's most likely a geometry issue. Vectorizing can be tricky and make a bunch of stuff that needs to be dealt with...
    Dec 2008
    4548
    Re: V carve tool path limit?
    Post the file. Let's see if we can help you get the job!
  1. V Carve and Tool settings
    By Sasign in forum Australia, New Zealand Club House
    Last Post: 11-08-2017, 11:02 PM
  2. Software/ Online tool to modify G-code for unidirectional 'Zig tool path'
    By eeu23b in forum Uncategorised CAM Discussion
    Last Post: 09-13-2017, 07:12 PM
  3. 3D Roughing/Finish Tool Path Not A Smooth Edge V Carve Pro 8.5
    By goozler in forum PhotoVCarve and VCarve Pro
    Last Post: 06-14-2016, 02:46 PM
  4. Set height for V-carve path on a model?
    By DonFrambach in forum Vectric
    Last Post: 06-24-2012, 10:47 PM
  5. Replies: 3
    Last Post: 10-07-2011, 05:45 PM
