588,483 active members*
5,011 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Fanuc Yellow Cap to Gecko 320X
    I am at a loss here as to what my problem is.
    I had my machine running fine up until a few days ago. I moved some of the components into a second cabinet due to noise issues through my USB.
    When I hooked everything back up, both axis started moving on their own and have remained uncontrollable. I confirmed my pinout. I have since unhooked the Z drive servo to try working one at a time. My status lights on the drive show green.
    Is anybody else running gecko drives to yellow cap servos? Odd thing is that I have another machine running the same setup and it is fine.
    I have about 7 hours into troubleshooting and feel like I'm worse off than when I started. Any experts that can weight in?
    Dec 2013
    5722
    Re: Fanuc Yellow Cap to Gecko 320X
    Maybe you have the X & Y encoders or motor outputs crossed when you reconnected?
    Jim Dawson
    Sandy, Oregon, USA
    Dec 2017
    10
    I´m running three of these servos with geckos 320x , previously i have changed the original tachogenerators with amt102 encoders . They running well , of course accepting the limited final velocity because the 80 volt max of the geckos ( yellow caps works normally near the 150 volts range ) . Torque peak was also lowered for the 20 amp limit , but still sufficient . Zero problems in 2 years of use daily . Have you managed to solve the problem?
  1. Gecko 320x
    By gabedrummin in forum Gecko Drives
    Last Post: 10-24-2016, 07:04 PM
  2. gecko 320x drive
    By pchfurniture in forum Gecko Drives
    Last Post: 12-01-2015, 02:48 AM
  3. Gecko 320X adjustment using a scope
    By Evolution in forum Gecko Drives
    Last Post: 02-14-2012, 12:36 AM
  4. Will A Gecko 320X drive these?
    By Jackal66 in forum Gecko Drives
    Last Post: 11-08-2011, 02:01 AM
  5. Why use breakout board with Gecko 320X?
    By pp7 in forum Benchtop Machines
    Last Post: 04-18-2011, 08:10 AM
