586,060 active members*
4,323 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > installing new resolvers alignment
    Mar 2012
    16
    I know the resolver for the Z axis needs to be rotated for spindle / tool changer alignment , but does the X or Y axis resolvers need any form of alignment after a new one is installed?
    Sep 2004
    148
    Re: installing new resolvers alignment
    Install the resolver, align the marks, do a cold start. Likely the marks will not align, so rotate the resolver until the marks align, same as Z axis
    Mar 2012
    16
    Unhappy Re: installing new resolvers alignment
    Quote Originally Posted by triumph406 View Post
    I am assuming even if I rotate the resolver, the X axis position will be close but does the Fadal find the orignal exact X position of the table. I have jigs that I have save the X Y locations and upload them every time I use those jig. Never have to dial indication them. Assuming those XY locations will be lost.
    Oct 2008
    1632
    You're right, you will loose those offsets. You are suppose to center the Y axis in the center Tee Slot using a dial indicator. Then the X will be measured to the center of the table from each end then align to that.
    It's important so the limits work right. Z axis resolver will need tool lengths done again, and X or Y will need fixture offsets done again.
  1. Resolvers Vs. Incremental encoders?
    By SwampDonkey in forum Servo Motors / Drives
    Last Post: 04-29-2017, 01:00 PM
  2. Installing VTC-41
    By Jmooresshop in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-25-2016, 08:21 PM
  3. Installing a DRO
    By aucran in forum Benchtop Machines
    Last Post: 05-02-2010, 06:50 PM
  4. dc drive with resolvers
    By don_harby in forum Servo Motors / Drives
    Last Post: 02-26-2006, 04:13 PM
  5. Resolvers?
    By lsfoils in forum CNC Machine Related Electronics
    Last Post: 08-31-2003, 12:56 AM
