603,893 active members*
3,529 visitors online*
    Dec 2009
    167
    Homing problem ESS
    Ess Mach3 Version R3.043.062 PLugin a-v10-f1
    Hi guys I have been using the ESS for a few years now but I just decided to try the ESS homing function
    and ran into a problem
    Homing works as it should under Mach3 Control
    But under ESS when it homes a axis it does not back off to reset the switch
    I use high quality optical switches
    any ideas
    cheer's
    Dec 2009
    167
    Re: Homing problem ESS
    Hi okay I had the same problem and the trick is to set the ports and pins in Mach3 ports and pins
    If you read the bottom line on the homing page of ess it says
    E) Only assign values to the three Index settings If you have an index pin or signal (i.e on an angular or rotary axis,not a linear axis)
    So leave the index port and pin as 0,0 in the ESS homing page
  1. Homing Problem
    By garryg in forum Mach Mill
    Last Post: 09-21-2014, 06:59 AM
  2. Homing Problem
    By red_alert in forum LinuxCNC (formerly EMC2)
    Last Post: 08-15-2010, 03:50 AM
  3. Homing problem
    By airtime in forum Uncategorised MetalWorking Machines
    Last Post: 06-07-2010, 11:27 AM
  4. X4+ homing problem
    By rzmac in forum Syil Products
    Last Post: 03-16-2010, 05:10 PM
  5. Just another homing problem
    By jeffrey001 in forum DIY CNC Router Table Machines
    Last Post: 06-01-2008, 01:18 AM
