586,100 active members*
2,615 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > Spindle atc bt30 5.5kw, 4 pole rate 220V 400hz, max 600hz 18000rpm .
    Mar 2005
    305
    https://www.ebay.com/itm/183702702635
    Spindle Motor Specifications :
    Power : 5.5KW
    Voltage : 220V
    Current : 20A
    Frequency : rate 400Hz max 600hz
    Speed : 18000rpm
    Cooling Type : Water-cooled
    Joint of nose : BT30 Taper 45o , petal
    Lubrication : Grease
    weigth: 26kg
    Diameter: 125mm
    Lengt: 460mm
    Air pressure: 6kg/cm2
    Mar 2005
    305
    Re: Spindle atc bt30 5.5kw, 4 pole rate 220V 400hz, max 600hz 18000rpm .
  1. sale spindle atc bt30 2 pole 380V 300hz 18000rpm brand new
    By tivoidethuong in forum For Sale Only
    Last Post: 02-25-2019, 09:15 AM
  2. Replies: 5
    Last Post: 02-17-2019, 09:21 AM
  3. Replies: 3
    Last Post: 01-28-2019, 07:22 PM
  4. Replies: 7
    Last Post: 03-22-2017, 03:48 AM
  5. Mach3 PWM Spindle Speed Control using 220v 1ph VFD/220v 3ph spindle motor.
    By Ozzwinkle in forum Mach Software (ArtSoft software)
    Last Post: 12-23-2013, 07:01 PM
