588,427 active members*
5,596 visitors online*
Thread: Part Counter
    Mar 2006
    Part Counter
    I'm using Flashcut to manufacture repetitive part. I'm trying to create a part counter to warn the user when it is time to replace/sharpen the tool. We are starting the program by pressing an external button that plugs into the flashcut controller- is it possible to programatically trap that input (by vb or C++) so that it can be counted in a seperate application that sits on the desktop?
    Aug 2005
    12
    I know you can make a part counter using parametric programming on a regular cnc control using a stored variable, I'm not sure if it would work with Flaschcut.
  1. Counter Mitutoyo
    By wanchai101 in forum Calibration / Measurement
    Last Post: 03-17-2007, 02:06 PM
  2. Parts counter
    By daewooevc in forum Daewoo/Doosan
    Last Post: 11-01-2006, 03:38 PM
  3. counter
    By cncsdr in forum Haas Mills
    Last Post: 11-08-2005, 02:56 PM
  4. G-code to zero counter?
    By erase42 in forum G-Code Programing
    Last Post: 07-19-2004, 04:01 AM
  5. counter-weights
    By georgebarr in forum DIY CNC Router Table Machines
    Last Post: 02-15-2004, 03:56 AM
