586,121 active members*
3,289 visitors online*
Page 1 of 3 123
Results 1 to 20 of 45
    Feb 2019
    91
    First Cnc Build With extrusion
    hi all its my first time to build the cnc some part already bought if there any suggestion for improvement please tell me thanks here list of the part with the cost and some of the picture
    1.JMC SERVO 20BIT 400Watt
    Power: 400W
    Speed: (Rated/Max) 3000/5000rpm
    Price : 190 USD EACH WITH THE DRIVER
    2.TBI OFU BALL SCREW 2005 C5 GROUND WITH C5 BALL SCREW SUPPORT ANGULAR BEARING
    970mm Double Nut Ground C5(OFU new version compare to DFU)
    Price: 210 USD each For 1 meter Length
    C5 Angular BallscrewSeat:30 Dollar Each
    3.ALUMINUM EXTRUSION 100*200 ,100*100,80*160
    100*200= 82 Dollar Each =2 Unit
    100*100= 40Dollar Each =3 Unit
    80*160 =32 Dollar Each =1 Unit
    4.2,2KW SPINDLE
    170USD With VFD
    5.HIWIN CGW20CC 20MM WITH STAINLESS STEEL STRIP RAIL
    CGW20CC BLOCK 20mm=15 Dollar Each =8 Unit
    CGR20R With Steel Strip =34 Dollar For 1 Meter=4X1 meter
    6.25MM AND 12MM ALUMINIUM SHEET 6061T6
    370mm*480 25mm Thickness 2Unit
    390mm*600 25mm Thickness 1 Unit
    480mm*510 12mm Thickness 1 Unit
    Total All=160 Dollar
    7.FOR Z AXIS IUSE LINEAR ACTUACTOR WHICH I GOT FOR FREE USING 2005 BALL SCREW WITH 4 15MM BLOCK HIWIN
    8.ESS Smooth Stepper Around 200 USD
    Total Damage for now
    1700 USD
    size 1 meter x1 meter effective dimension 60cm*70cm
    Dec 2014
    640
    Re: First Cnc Build With extrusion
    Access to your anti-backlash nut is easy, but I'd be concerned about that thin little piece of aluminum transferring motion from the screw to the Z axis carriage. Probably ok for most operations I guess.
    Feb 2019
    91
    haha yeah im still thinking about nut holder design maybe i should do V shape
    Dec 2014
    640
    I would think a V shape would work better.
    Feb 2019
    91
    ok for my concern now is the spindle and y axis block which is far do i need to make it more near to spindle i would lost around 100mm working dimension for it
    Mar 2018
    68
    At those price i relly would like to know where you are sourcing your aluminum extrusion
    Feb 2019
    91
    Quote Originally Posted by HuguesP View Post
    hi all the part i buy mostly from china and taiwan since i stay near them that price already included with custom cut and thread
    Oct 2009
    733
    Teamloks1, where are you located?
    Feb 2019
    91
    im from Malaysia
    Oct 2009
    733
    Thank you,
    The prices you quoted for the extrusions would
    be too good to be true here in the US.
    Oct 2009
    733
    I think one point of concern could be the side-to-side
    movement of the gantry held in place. Even though
    it has 10 bolts per side at the gantry, the bottom is
    (structurally speaking) not a 'fixed end'. It relies on
    the rigidity of the side plates and becomes a cantilever.
    Moving the linear rail to the top slot would shorten
    that cantilever. (Suggestion 1)
    Adding another rail to the bottom slot would make
    it a (vertical) beam with two somewhat fixed ends.
    (Suggestion 2)
    Attachment 414122
    Mar 2018
    68
    75mm x 150mm x 600mm extrusion is 100$cad = 75$ usd here in canada,
    Feb 2019
    91
    Quote Originally Posted by davida1234 View Post
    (Suggestion 2)
    Attachment 414122
    thanks for suggestion,and yes the second suggestion is my original design but i saw somewhere said i dont need double rail for y axis so i go for single rail since i already order some item maybe i opt for suggestion 1
    yeah got just got quote from my reseller that around 28$ for 1 meter length
    Feb 2019
    91
    some of part already arrive its TBI motion 2005 ball screw
    Feb 2019
    91
    just some side view
    May 2005
    3920
    Quote Originally Posted by teamloks1 View Post
    just some side view
    Whats with all the extra bearings on the X? IF I'm looking at it right you have two rails and four sets of bearing blocks on one side of the machine. I'm assuming the same on the opposite side. This is not a good idea. It is very difficult to get the linear rails in plane and adequately parallel with each other mounted directly to extrusions. If you don't think the rails or bearing blocks are suitable for the loads applied as a single rail you would be far better off addressing that either by larger blocks or up sizing both the bearing blocks and linear rails. You can find threads on here where guys have tired to do so with much heartache, extrusions are simply not that precise to allow closely mounted rails like you have here.
    I'm not a big fan of the Y axis arrangement either as it simply wastes hieght in the Z. You will likely loose close to two inches in Z with the wrap around gantry (Y) saddle. I'm als not a big fan of added complexity that offers little in return.
    Feb 2019
    91
    thanks sir for suggestion i will try to improve it back still got 2 weeks before all item arrive
    Feb 2019
    91
    i think will go with this design since i can tuck the servo
    Attached Thumbnails Attached Thumbnails Side left.jpg   Rightr 1.jpg   Front5.jpg   Front.jpg
    May 2005
    3920
    I like that latest design. Hope to see it running soon.
    Do remember you need to keep in mind drag chains and other bolt on components. Often these are left as after thought and it often shows.
    Feb 2019
    91
    haha yeah thanks just lazy to draw chain and bolt but i got it in my mind currently thinking to use 4kw atc bt30 or iso20 2.2kw
Page 1 of 3 123
  1. 4x9 CNC Wood/Steel/Extrusion build
    By javabugz in forum CNC Wood Router Project Log
    Last Post: 01-19-2021, 03:14 AM
  2. Aluminium-/Extrusion CNC Build
    By millhouse_ in forum DIY CNC Router Table Machines
    Last Post: 11-08-2018, 07:54 PM
  3. 80/20 extrusion router build
    By jfong in forum CNC Wood Router Project Log
    Last Post: 09-12-2018, 05:10 PM
  4. 1st build, Aluminium extrusion based
    By andtfoot in forum CNC Wood Router Project Log
    Last Post: 11-20-2015, 03:46 PM
  5. What extrusion should I use to build a cnc table?
    By EKFER in forum 80/20 TSLOTS / Other Aluminum Framing Systems
    Last Post: 05-16-2012, 04:55 PM
