586,100 active members*
2,615 visitors online*
    Apr 2018
    5
    LUBE Pump - Help
    I have a Willy-Vogel (122 024 510) lubrication pump that I have all intentions on using. I contacted VOGEL an the pump has been discontinued and can not help. Does anyone have a schematic or explanation of how this is wired? There are 2 cables coming out of the unit. One is power (3 conductor) which I am able to trace easily enough and I assume the other is control (2 conductor) or pressure switch, but I don't know for sure. The cable goes into a boot and I don't want to try going into if I don't have too. Any insight of the unit is greatly appreciated.
    Feb 2009
    6028
    Re: LUBE Pump - Help
    Probably a float switch. Stick a meter on the 2 and turn the pump upside down and right side up. Circuit should close and open.
  1. Leaking Lube Pump
    By dkaustin in forum Tormach Personal CNC Mill
    Last Post: 04-13-2013, 02:18 AM
  2. Lube pump
    By TarHeelTom in forum LinuxCNC (formerly EMC2)
    Last Post: 02-26-2012, 06:14 PM
  3. re Spindle Lube and Lube Pump
    By robkuhi in forum Tree
    Last Post: 10-24-2011, 06:49 PM
  4. Lube pump
    By TarHeelTom in forum Bridgeport / Hardinge Mills
    Last Post: 08-19-2010, 06:48 AM
  5. Auto Lube pump?
    By cncuser1 in forum Syil Products
    Last Post: 05-04-2008, 10:19 PM
