586,035 active members*
3,716 visitors online*
    Oct 2018
    13
    Tube problem or what?
    Hello friends!
    Im having a problem with my 1390 Co2 Laser machine when i try to engrave photos.
    Im using 25% of power in one 100w reci w2 tube.
    Problem is that laser starts to engrave for 20-30 seconds and after power drops to much and not engraves nothing.
    Power supply shows around 0.5 to 0.9 ma with 25% power.
    I did some test with 50-60% and shows around 11 to 15 ma.
    With 80% reaches 27 ma.
    Another strange thing is that i tried to engrave txt with 25% and all goes fine.
    I dont know why with bmp images happens this.
    Thnx in advance!
    Oct 2018
    13
    Re: Tube problem or what?
    Pls someone help me with vendor and user settings files for 1390 laser because i reset to default and now axis move bad.
    Oct 2018
    13
    Anyone wich can help me??
    Dec 2018
    21
    Which company did you buy from?
    This is an old post but, if using RDWorks change your your page settings to match your machine. You can also rest home on the machine by setting it manually with the origin button. Your machine's control software my be trying to reach a home point that your machine cannot get to.
    Sent from my SM-G935F using Tapatalk
  1. laser tube problem
    By geekinesis in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-21-2016, 09:12 PM
  2. Laser tube problem or?
    By _MI_ in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-01-2015, 07:03 PM
  3. problem with PSU wiring for 80W Reci CO2 tube - only getting 4 mA output to tube
    By gbatten in forum Laser CO2 Tubes, Diodes, RF and Power Supplies
    Last Post: 01-06-2015, 12:53 AM
  4. Tube problem or powersupply problem? Help you to check out
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-05-2012, 04:09 AM
  5. Drain Tube Problem
    By hgporter@porter in forum Shopmaster/Shoptask
    Last Post: 07-31-2008, 10:56 PM
