586,069 active members*
3,498 visitors online*
    Jun 2010
    27
    Saving G54 without leaving the programm
    Hello,
    I've been using Mach3 for more then 10 years now and I've allways wonderd if it is possible to save the G54 (0-point) without leaving the programm.
    Sometimes, if I'm running big files, the programm tends to crash because of an overload of the smoothstepper when I stop before the end of the programm. This can be a big problem.
    If you leave the programm, you get the question if you want to save the settings, but I've never found this option while running the programm.
    Does it exist?
    Thanks in advance, Bas
    Re: Saving G54 without leaving the programm
    Isn't already saved as G54?
    The dialog on shut down only preserves it for next startup. If you aren't closing the program it's still there. Just reference the machine, then hit X0Y0Z0 and it should go right to wherever you set G54.
    Jun 2011
    692
    I think he's referring to saving it in case Mach crashes.
    Sorry, I don't have an answer.
    Go to the offsets page and click "save offsets".
  1. Xilog Macros programm
    By rieco2 in forum CNC Machining Centers
    Last Post: 11-08-2017, 02:49 PM
  2. which programm i need
    By beginer123 in forum G-Code Programing
    Last Post: 10-01-2014, 06:53 PM
  3. Adding alphabets with programm number
    By rajanvadakkepat in forum Fanuc
    Last Post: 11-01-2011, 01:40 PM
  4. multi depths in 1 programm
    By ajitsingh in forum Bridgeport / Hardinge Mills
    Last Post: 02-23-2007, 05:11 PM
