586,728 active members*
3,124 visitors online*
    Dental 4-axis machine + mach3
    Hello, my colleagues!
    At first: sorry for my non-professional vocabulary. This is the first time when I face this problem and specialists in this field.
    My story in a few words: I am a dentist. We purchased a machine for milling crowns and bridges Wieland 4030 (as I understand built on the basis of ISEL 4030, 4 axis) When we got it, we realized that there was a problem with connecting. After many attempts, we sent to a repair center where it was accepted the decision to replace the old controller and servo drives with new ones. After the upgrade, we got a machine that is fully driven by MACH 3, but now we are in search of a program that can generate for the Mach3 CNC file.
    I install on my computer PowerMill 2017, but I have no idea how to connect it with my CNC.
    As well, I have downloaded the dentist version of PowerMill DentMill (the project had been closed in 2015).
    The main task is to mill crowns and bridges in 4 axes with an auto-change tool(we used 3 milling burs). We simulate crowns in the CAD program, and then we get an STL file. After that, it needs to be milled.
    I attach a photo of the machine to the post.
    I ask your advice in this case. For any information and direction I will be very grateful. You are my last hope. Thanks!
    Re: Dental 4-axis machine + mach3
    You don't connect Powermill to Mach3.
    You create toolpaths in Powermill, and export g-code.
    You then load the g-code into Mach3 to control the machine.
    Gerl, Thank You for the answer.
    Sorry for incorrect description.
    How should i create toolpaths for Mach3 in my case? (coordinates, choose tools).
    Dec 2013
    5717
    This would be a good place to start.
    Jim Dawson
    Sandy, Oregon, USA
  1. need help / dental technician / 5 axis milling
    By flasherbil in forum FeatureCAM CAD/CAM
    Last Post: 06-05-2015, 11:18 AM
  2. Mach3/Kflop - Homing 3 axis machine
    By slimneill in forum Dynomotion/Kflop/Kanalog
    Last Post: 02-13-2015, 08:31 PM
  3. MadCam 4-axis, Mach3 & machine crashes??
    By dwneumann in forum MadCAM
    Last Post: 12-27-2012, 09:39 PM
  4. Anyone built a dental machine?
    By brian257 in forum Uncategorised MetalWorking Machines
    Last Post: 08-02-2012, 07:44 PM
  5. Replies: 4
    Last Post: 08-15-2011, 03:04 AM
