586,700 active members*
2,822 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Anilam crusader m control problem.
Page 3 of 4 1234
Results 41 to 60 of 79
  1. #41
    Mar 2005
    271
    ENA - and ENA+ are the enable pins, it might be possible to use these, but many times can be unused. The AOUT is the command signal, and the GND is the command common. These would be connected to the command input pins on the drive.
    OK so I finally got everything wired and my kid tripped over the 5i25 and 7i77 cable and unplugged it while it was on, now my drives make a high pitch noise and the red lights on the drives don't come on anymore, did this fry something on the board Jim?
  2. #42
    Dec 2013
    5717
    Re: Anilam crusader m control problem.
    Quote Originally Posted by CATCH22 View Post
    Not likely that something is fried, I would be looking for loose connections. The high pitched noise is the carrier frequency. I have one drive that is really annoying.
    Jim Dawson
    Sandy, Oregon, USA
  3. #43
    Mar 2005
    271
    OK thanks Jim.
  4. #44
    Mar 2005
    271
    Hey Jim, before this happened the servo drives didn't make any noise and there was one red light on, on each of them, now no lights are on, on the drives,and the have that high pitch noise.
  5. #45
    Dec 2013
    5717
    Did the motors run before the plug was pulled?
    Jim Dawson
    Sandy, Oregon, USA
  6. #46
    Mar 2005
    271
    No the motors weren't running yet.
  7. #47
    Dec 2013
    5717
    Do you have a manual for those drives. I have no idea what the LED(s) mean. The sound probably means that the drive is enabled, but without some documentation it's hard to tell what is going on.
    One note, make sure the motors are mechanically disconnected from the machine until you know you have the motors under computer control. They have enough power to break something if they run away, which is common when setting up a new system.
    Jim Dawson
    Sandy, Oregon, USA
  8. #48
    Mar 2005
    271
    Unfortunately I don't have a manual for those drives, and yes I did already remove the drive belts off of the servos.
  9. #49
    Mar 2005
    271
    Maybe this will help.
  10. #50
    Dec 2013
    5717
    I am not able to locate a manual for those drives. You are going to have to do some research to see if you can find one. I would check with board rebuilders, or ANIMLAM User Support :: Acu-Rite
    Maybe https://www.illianaindtech.com/html/anilam.html
    Also Google Anilam and start checking the hits. It is possible that the LED(s) are labeled on the board and that might give some indication of what they mean. Without some documentation we are just shooting in the dark.
    Jim Dawson
    Sandy, Oregon, USA
  11. #51
    Mar 2005
    271
    Thanks Jim, I just uploaded a picture of the lights on the drive, VE EC GF SC are what it shows next to the lights.
  12. #52
    Dec 2013
    5717
    Unfortunately those labels are too cryptic to decipher.
    Jim Dawson
    Sandy, Oregon, USA
  13. #53
    Mar 2005
    271
    OK I will see what I can find for a manual.
    Thanks Mike
  14. #54
    Mar 2005
    271
    Quick update, just got home from work and turned the mill on, the servos have power to them and all are turning very slowly, so I hope this means my Mesa boards are fine.
  15. #55
    Feb 2008
    644
    That is a good sign (expect them to drift until the feedback loop is closed in LinuxCNC)
    BTW this is what the drive enables are for, the drives should not be enabled unless LinuxCNC is in control
    so you should never see drift on a properly wired/configured system
    This is a safety issue because you want LinuxCNC to be able to disable the drives when it senses a fault
  16. #56
    Mar 2005
    271
    And I'm assuming that will all be done using pncconf.Is that correct?
  17. #57
    Feb 2008
    644
    Actually no, this is a mainly a wiring issue (and understanding how your drive enables work)
  18. #58
    Mar 2005
    271
    Quote Originally Posted by PCW_MESA View Post
    Oh ok, I guess I will have to do some more research on that.
    Thanks PCW
  19. #59
    Mar 2005
    271
    Is there a wiring drawing I can find that shows the proper way to do it with the 5i25 and 7i77 on a 3 axis mill?
  20. #60
    Feb 2008
    644
    This is dependent on how the drives enable signal works, have you found any documentation on the drive or original mill wiring diagrams?
    Do you have the drive part number and manufacturer?
Page 3 of 4 1234
  1. Programming Anilam Crusader II L Lathe Control
    By 57chevy in forum Controller & Computer Solutions
    Last Post: 06-03-2014, 06:30 PM
  2. help repairing Anilam Crusader II control?
    By wddanie in forum Bridgeport / Hardinge Mills
    Last Post: 02-15-2013, 06:03 PM
  3. My New/Old Anilam Crusader M has a problem
    By L98FIERO in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-15-2008, 01:10 PM
  4. ANILAM CRUSADER II Problem
    By ataylor_316 in forum Bridgeport / Hardinge Mills
    Last Post: 09-21-2007, 12:04 PM
  5. Anilam Crusader M problem
    By Rot Iron Racer in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-18-2007, 08:15 PM
