586,106 active members*
3,078 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Convert my pgm drawings to dxf without xilog
    Feb 2019
    6
    Hi there can anyone help me convert my pgm xilog drawings to dxf dont have access to xilog plus no more is there and other sofware i can use
    Aug 2009
    1573
    Re: Convert my pgm drawings to dxf without xilog
    Search ... Convert pgm to dxf.
    Feb 2019
    6
    Hi ive tried all types of file conversion software and dont get no drawings from them i asked alphacam if there software was capable of it sent them a file and they sent a dxf drawing back but i nearly fell over when i asked how much alphacam was £4000????
    .pgm files are g-code, usually in a binary format. You'd usually use WinXiso to convert them to g-code text files. Then another converter to go from g-code to .dxf
    You'll never end up with the same drawing that you started with.
    Feb 2019
    6
    Thanks i have winxiso which xilog uses when i open the file theres all of the text x and z positions etc but just really struggling to actually get a drawing back from them i understand that if i do that the drawing will probably want scaled or so when alphacam opened them the drawing were exactly as they were
  1. Xilog: How to convert PRG to PGM
    By blur in forum CNC Machining Centers
    Last Post: 02-13-2017, 03:58 PM
  2. Replies: 4
    Last Post: 02-19-2016, 04:39 AM
  3. convert genesis to xilog?
    By m9g in forum CNC Machining Centers
    Last Post: 01-02-2015, 06:13 PM
  4. Replies: 3
    Last Post: 07-01-2011, 06:19 PM
  5. Setting Limits In TurboCNC? Also convert line drawings?
    By Patrick_M in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-02-2008, 06:21 PM
