586,546 active members*
3,433 visitors online*
    Mar 2008
    114
    Spindle orientation 0imc
    Hello all, hope someone here can help. Working on a machining centre and the spindle will not orient for a tool change or m19, it just spins. The machine has beta motors and drives, and there is a prox switch connected to the spindle drive that reads a gap in a ring on the spindle. The prox is working and voltage is coming into the spindle drive but for some reason the machine doesn't see it. Any ideas?
    Sent from my G8343 using Tapatalk
    Dec 2009
    958
    Re: Spindle orientation 0imc
    what happend before?did u canged the belts?
    go into diagnose at 445 and check by rotating the spindle with hand if the position data from 445 diagnose is same with value in parameter 4077 when the proximity sensor is on the gap,if not ,adjust by changing the value of param 4077 that is 4096/360 degrees
  1. spindle orientation
    By Clyde_06 in forum Fanuc
    Last Post: 01-25-2016, 08:51 PM
  2. spindle serial link error 750 Fanuc 0IMC
    By ahmed4040 in forum Fanuc
    Last Post: 01-19-2016, 12:28 PM
  3. Spindle orientation
    By jrogus in forum Haas Mills
    Last Post: 08-23-2009, 04:18 AM
  4. Spindle orientation
    By jimecv in forum Daewoo/Doosan
    Last Post: 11-09-2007, 06:25 PM
  5. Spindle Orientation
    By machinist39 in forum Haas Mills
    Last Post: 05-05-2006, 02:58 AM
