603,390 active members*
2,854 visitors online*
    cutting 1/4" thick carbon fibre
    hey guys
    I am looking at using some 1/4" CF hard sheet for parts in paintball markers
    Would using flood coolant be OK to use
    Also what depth of cuts should I use , I am going to use the following cutters DIAMOND CUT - UPCUT - FC - ROUTERS between 3/32" and 1/8 dia
    all help is really appreciated
    acidcustom
    Sep 2004
    140
    I machined some 1/4" cf plate recently for a radio control helicopter I am building. My setup is Dremel Advantage mounted to the quill of a Bridgeport CNC. My skill level is hobbyist and speed wasn't as big a factor as quality. With a 1/16" carbide burr spinning 30K RPM I cut full depth at 10 IPM. I had an air blast nozzle (no liquid) and manually held a shopvac nozzle to help suck the dust.
    thanx at least I know I can cut full depth
  1. CNC filament winder(carbon fibre)
    By wallygator99 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-22-2014, 10:49 PM
  2. Routing Carbon fibre laminate
    By kong in forum Composites, Exotic Metals etc
    Last Post: 04-09-2007, 05:08 AM
  3. quest for knolege, looking for carbon fibre info?
    By Bartman in forum Composites, Exotic Metals etc
    Last Post: 04-09-2007, 04:36 AM
  4. 4" thick foam inserts
    By kdoney in forum Employment Opportunity
    Last Post: 06-12-2006, 10:55 AM
  5. Best Mill for 1" thick Aluminum?
    By gtslabs in forum Uncategorised MetalWorking Machines
    Last Post: 01-01-2004, 04:37 AM
