603,945 active members*
3,908 visitors online*
Hybrid View
pythonsoft Z axis switch 04-29-2019, 08:57 PM
c3h2o79 Re: Z axis switch 02-22-2021, 08:58 PM
    Apr 2019
    5
    Z axis switch
    Hi I have fitted a switch to my z axis for a floating switch, it is set in inputs as 1 pin13 and when I trip the switch manually it lights up In diagnostics as m3 home but when I move the z axis the switch does not stop it .
    Jan 2015
    Re: Z axis switch
    If you are setting this switch as "probe"....the switch stop Z axis only with command G31. Testing G31 Z-200 F300 and Z axis will stop when lights up.
  1. PCB-0200 Axis switch
    By jbranting in forum Fadal
    Last Post: 02-03-2017, 08:28 PM
  2. bought new g540 had to switch x axis with a axis
    By phukawat in forum Gecko Drives
    Last Post: 07-24-2015, 08:35 PM
  3. Mastercam Lathe - Switch between D axis, and X axis
    By rjCousineau in forum Mastercam
    Last Post: 04-13-2015, 07:33 AM
  4. how to switch off only A axis?
    By xaco in forum Mach Mill
    Last Post: 09-06-2010, 12:06 PM
  5. Z axis zero indicator switch
    By cnc rider in forum Mach Mill
    Last Post: 09-29-2006, 05:00 AM
